AutoCAD FAQ
Knowledgebase Home | Glossary | Favorites | Login Knowledgebase Home | Glossary | Favorites | Login
My delete key doesn't work
Article Details
Last Updated
3rd o December, 2008
Original Author
Alan Cullen
User Opinions (18 votes)
83% thumbs up 16% thumbs down
How would you rate this answer?
Helpful
Not helpful
First, check that the object that can not be deleted is not on a "locked" layer. Use the command LIST to find out what layer the object is on. Locking a layer will prevent deletion of any entity on that layer.
To check if the layer is locked or not, go to Layer Properties Manager, and check the layer there:
If the layer is not locked, and the object still can not be deleted, then proceed with the following:
Check the setting of the PICKFIRST variable. This variable controls whether objects are selected before or after a command is issued.
The settings are:
0 - Select objects after the issue of a command.
1 - Select objects before or after the issue of a command.
Generally, PICKFIRST should be set to 1
Another way to set PICKFIRST is to go to the menu TOOLSOPTIONSSELECTIONSelection ModesNoun/Verb check box. If checked, PICKFIRST is set to 1.
Visitor Comments
  1. Comment #1 (Posted by Capdog )
    I'm a new CAD user, and I'm trying to edit a an existing file. More specifically, I'm trying to delete some text, but the program is not letting me. What am I doing wrong?(Please refer this question to the main forum area. You will get a better response there. AKC 27-03-2008)
  2. Comment #2 (Posted by Tayab)
    Suddenly, I found that my delete key is no longer working. This article proved very useful to me, And now my delete key is working as before. (yeay! :) - Tiger - 080623)
Post Comment for "My delete key doesn't work"
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
Related Articles
No attachments were found.
Continue
Creative Commons Licence
Powered by Interspire Knowledge Manager
