Welcome to our knowledge base. To find what you're after, use the search box below or choose a category to view listed articles.
This is a live project and the FAQ database is being constantly updated by our team of experts. Currently, there are over 40 additional answers to common questions in preparation.
A common misconception about PDF drawings is that the process is to
convert a DWG file format to a PDF file format. A PDF file is a digital
'paper' plot of the drawing, not an actual hardcopy paper plot of the
drawing. Since a PDF file is generally a raster image file, it can be
modifed by any clipart application, and because of that a PDF file
should never be considered unalterable and should be handled and
distrubuted with caution.
A PDF file is created via a PDF printer which works like an ordinary printer or plotter, the only difference being that the drawing is not sent to a printer to obtain a hard copy of the drawing, but is instead 'printed' to a PDF file. The PDF file can then easily be distributed via e-mail to be plotted to hardcopy elsewhere.
This file can be opened in Adobe software (or similiar free software) from where it can be produced as a hard copy print as required.
After installation, the PDF printer will show up in the AutoCAD Printer/Plotter selection. Just select the PDF printer in the Plot Dialog Box and a prompt will appear requesting a location to save the PDF file to.
If a more feature rich PDF is required, and funds are available, there are a few options. Among them are:
bluebeam This software enables the creation of markup drawings within AutoCAD.
AutoCAD 2008 and 2007 are packaged with a PDF printer. With the inbuilt AutoCAD PDF printer, a script file can be created which will run without waiting for a resultant file name.
Visitor Comments
Comment #1 (Posted by kenneth burch
I usually do my drawings in Adobe Illustrator because I'm working with lots of custom typefaces, and need the color fills and gradients to generate a 2-D sketch before rendering in a 3-D Cam program (much like a sign maker or jewelry designer. Well, I've updated to CS3 and now when I Export my thinly stroked AI vector file as a DWG all seems well when I open it in A/Cad LT 2008. The trouble seems to occur when I paste the newly opened DWG into a pre-made template (title blocks set up and descriptive type areas at the ready). Suddenly the DWG becomes tiny and blocky. I reversed the order and It worked better, ( Opening the template > Select all > Copy and past It into the newly opened DWG. I also noticed that if return to the previous version of Adobe Illustrator(CS2) things go better but I still have to reverse the order as described above. Is anyone else dealing with minor issues between AI-CS2or 3 into A/CAD? (Wow, I think that is beyond the ambit of the FAQ, and the knowledge that the FAQ team have. I strongly suggest you take that question to the general forum area, where the other members may have an answer for you. AKC 8-04-2008)
Comment #2 (Posted by Anonymous)
In truth, a PDF file at its simplest is just a digital 'paper' file that can't be altered
I think this statement can lead to a false sense of security. As everyone knows, a pdf can be edited with the right software. (Included-Tiger-27 May 08)
Comment #3 (Posted by pRAMOD kUMAR sRIVASTAVA
How to make a PDF drawing (Please take your question to cadtutor.net/forum - Tiger - 29 June 2008)
Comment #4 (Posted by Amit
This Amit sharma ,
recentaly Lecturer in gurukul engineer college kota , in CS branch,
but i am fully perfectly workout in AutoCAD
I Want to some important questions and Answer that is related to the AutoCAD 2d or 3d porsition
so i want to some solution of AutoCAD
Thanku (Please take your question to cadtutor.net/forum - Tiger 080922)
Comment #5 (Posted by Doug Mighell
The pdf files produced by my draftsman (autocad 2008 w/ built in pdf maker) are huge (1-3M). We tried bringing the resolution down to 150 dpi and that only helped a little. Are there any other ways to get reasonable sized pdfs from autocad? (Please take your question to cadtutor.net/forum - Tiger 081110)
Comment #6 (Posted by Sanjay Gurnule
To convert anyfile we required a converter, for e.g. if i have any of the converter like PrimoPDF to convert autocad drawing to PDF; How to go futher with all details to get it exactly? (Please see Cadtutor.net/Forum - Tiger 081224)
Comment #7 (Posted by Mathew Antony
Is it possible to convert a pdf file drawing back to a AutoCad file. If yes How?
Thanks In Advance (Please take your question to Cadtutor.net/Forum - Tiger 090119)
