Is there a way to change the amount of lines that a made when I extrude a circle? I get 4 lines traveling from circle to circle. Same appearance when I revolve a rectangle. I want something that looks like when I revsurf a rectangle, but without the lines traveling to the center of the circle. I want it to look like a drilled hole from the top view but look like a circle with a thickness from the side.( I can't use a circle with thickness because I need to subtract the item from a polyline shape. )
revolve test.dwg
Isolines? From AutoCAD Help files:
"Specifies the number of contour lines per surface on objects."
The default for this variable is set at 4. Increase it. The max setting is 2047.
Thank you! That worked exactly like I had hoped. This site is the best! :DThanks for your help and your quick reply.
You're entirely welcomed TheNewGuy. Glad to be of service. :)
