muck Posted November 10, 2009 Posted November 10, 2009 AutoCAD 2010. I have an attached pdf reference attached to my autocad file. It is for back ground. In 2010 you can fade the pdf attachment on screen. How can I print that pdf attached with fade? Is that possable? Thank you, Quote
tzframpton Posted November 10, 2009 Posted November 10, 2009 AutoCAD 2010. I have an attached pdf reference attached to my autocad file. It is for back ground. In 2010 you can fade the pdf attachment on screen. How can I print that pdf attached with fade? Is that possable? Thank you, If it's a vector PDF, then no. If it's a raster PDF, then try putting it on a layer with a color that has a dithered screening percentage in the Plot Style. This works with me for TIFF. Quote
muck Posted November 11, 2009 Author Posted November 11, 2009 How do you make a Raster PDF vers a vector Pdf. I have been using PDF attach at the command prompt to bring the pdf's in. Quote
tzframpton Posted November 11, 2009 Posted November 11, 2009 A vector PDF is one that's created directly from AutoCAD. A raster PDF is a document that's been scanned in, sort of like an image. Converting the PDF to TIFF will actually be your best option. I know for a fact you can screen a TIFF image where it's "faded" when you plot. Quote
muck Posted November 17, 2009 Author Posted November 17, 2009 Can pdf files attached in 2010 be viewed in AutoCAD 2009?? Quote
tzframpton Posted November 17, 2009 Posted November 17, 2009 Can pdf files attached in 2010 be viewed in AutoCAD 2009?? Never tried. Since we've all upgraded to 2010 we've ridden 2009, or at least I did since. I doubt it tho.... Quote
paulliapa Posted November 10, 2010 Posted November 10, 2010 Yes if you are on subscription then you just need to download & intall AutoCAD 2009 - Bonus Pack 2 - PDF enhancements. Check out this article on-line: http://cadpanacea.com/node/79 Paul Li Can pdf files attached in 2010 be viewed in AutoCAD 2009?? Quote
