Good night from Spain. Forgive my bad English.
I would like to know if it is possible through Reactor automatically blocks or Lisp count?
The idea would be:
A legend with symbols (blocks) put each symbol on the plane and in the same legend that was the total number of symbols appearing there in the plane.
Command ._DataExtraction is not really what I want.
I´m just looking for the possibility to insert a legend of symbols (block) and when I use ine of these symbols in a drawing, the legend is updated automatically
Example:
Legend of symbols BEDS. If I insert a symbol (i.e 90cm bed) the legend will update the number of that symbol every time I use it.
It is like a symbol counter in the legend.
Leyend. Produccion Mecanica (Rociadores).zip
Have you actually tried using it? What you describe is possible with ._DataExtraction. You can export the results to a table in the drawing, which updates when additional blocks are added or removed.
I tried but I can not do it. Can you help me?
updates when additional blocks are added or removed?
I can not do with the application _DataExtraction. As will this take?
