MarkCalvert Posted December 29, 2010 Posted December 29, 2010 Hello, I'm pretty confident that this can be done as I've done it before but I'm suffering from a mental block (to many mine pies!). I have a list of a hundred or so points with x and y coordinates. I want to insert these into AutoCAD without putting each on as a single point. I think it was done by setting the pdmode and pdsize then another command? Any help would be very appricated. Cheers, Mark Quote
ReMark Posted December 29, 2010 Posted December 29, 2010 Are you using a txt or csv file by any chance? Quote
MarkCalvert Posted December 29, 2010 Author Posted December 29, 2010 None of the above, I just have the coordinates listed in an excel spreadsheet. Quote
ReMark Posted December 29, 2010 Posted December 29, 2010 What symbol do you want to use to represent each point? Quote
ReMark Posted December 29, 2010 Posted December 29, 2010 The answer you were searching for was right here under both ours noses: Michael's Corner. Click on the link below. Scroll down to the section called The Odd Spot. Michael explains how to get coordinates from Excel into AutoCAD. http://www.cadtutor.net/corner/2009/may.php Quote
MarkCalvert Posted December 30, 2010 Author Posted December 30, 2010 Thats excellent, I knew I'd seen it before! Many thanks once again, Mark Quote
MarkCalvert Posted December 30, 2010 Author Posted December 30, 2010 I changed the script file to 'point' and its point a point in at each location I needed. Saved hours! Happy new year, Mark Quote
BIGAL Posted January 4, 2011 Posted January 4, 2011 Easier still if you just want a point trying to remember its another post here copy the x,y of all the points in one go from excel In autocad "point" then paste all should appear in one go. This works for line & pline etc as well Quote
