browen Posted March 28, 2011 Posted March 28, 2011 Help! imageframe comes up as an unknown command. I have been looking for a solution, nothing is working! Quote
SLW210 Posted March 28, 2011 Posted March 28, 2011 What have you tried? What did you do just before it quit? Has it ever worked? Have you messed around with acaddoc.lsp? Does it work with Express>Tools>System Variable Editor? Quote
browen Posted March 28, 2011 Author Posted March 28, 2011 It has always worked until today. Earlier today I installed the image hotfix for the SP1, as directed, to correct a different problem. It seemed to be working fine, until i ran across this new problem... I combed through advice and tried several commands but nothing worked, so I uninstalled the hotfix and imageframe is working fine now. At the same time I went into all the xrefs of the first affected drawing and removed every image that was not absolutely necessary, and now that drawing is working better, or at least not crashing every time I try to zoom. Happy Monday to me. Quote
