Dimensions next to line while drawing
Hello, new to the forum. :D
I have recently gotten Autocad 2012 and played around. I am trying to figure out how to make the dimensions of a line that you are currently drawing show up in standard units (feet inches). Right now it shows up as numbers with decimals. I tried DIMSTYLE but couldn't figure out what to change.
Command: UNITS
More specifically, UNITS > Length type > Architectural
... and then when you get around to adding dimensions, then you'll go into DIMSTYLE and change "Primary Units" to Architectural as well.
Don't forget to set your Precision while you are in the UNITS dialog box.
