Command to Save a file with a specific name using a single command
I need to save a drawing file and give it the name of my desire using a single command, I don't want to issue "saveas" and then specify the name in the file name prompt. This problem is has been faced when I was using ScriptPro and I couldn't succeeded to do that. Hence I need to know if it is feasible to do the stuff using a single command. It will be preferred if I can choose the location to save the file also rather than save the file to the default location.
you can turn the file dialogue by setting FILEDIA=0. Once that is done you can supply the file name on the command line. If the file location & name don't have any spaces in them you can supply the name directly from script but if there are spaces enclosing the name in quotation marks ("....") is necessary.
