btraemoore Posted May 24, 2012 Posted May 24, 2012 (edited) Im trying to saveas the work ive done as a different file name, and i keep getting "script out of range" can some one throw me a bone? ' Declare Working Directory Global Const WrkDir = "C:\Documents and Settings\moorerb\Desktop\asset worksheets\" ' Declare Excel Workbook name Global Const Master_WorkBook = WrkDir & "bptags.xls" Global Const Secondary_WorkBook = WrkDir & "mytemp.xls" ' Declare Excel Worksheet name Global Const Master_WorkSheet = "ccu3" Global Const Secondary_WorkSheet = "mytemp" Global workbooks As Object Global ExcelVer As Integer Global ExcelServer As Object Global ObjWorksheet As Object 'Global SecWorksheet As Object 'Global ObjWorkbook As Object Global FileSaveName As String ' end of global variables Sub RetrieveEXC() Set ExcelServer = CreateObject("Excel.Application.11") Set workbooks = ExcelServer.workbooks workbooks.Add ("C:\Documents and Settings\moorerb\Desktop\asset worksheets\mytemp.xls") workbooks.Open (Master_WorkBook) Set ObjWorksheet = ExcelServer.ActiveWorkbook.worksheets(Master_WorkSheet) 'ExcelServer.WindowState = -4140 ExcelServer.Visible = True FileSaveName = WrkDir & Dwg_Name & ".xls" 'Set SecWorksheet = ExcelServer.ActiveWorkbook.worksheets(Secondary_WorkSheet) [color="red"]the line below is where my issue lyes.[/color] workbooks(Master_WorkBook).Sheets(Secondary_WorkSheet).Move After:=workbooks(Secondary_WorkBook).Sheets(1) workbooks(Secondary_WorkBook).SaveAs FileSaveName, fileformat:=56 set_to_null '---------------------------------------------- ActiveWorkbook.SaveAs FileName:= _ FileSaveName, fileformat:= _ xlNormal, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False _ , CreateBackup:=False '---------------------------------------------- End Sub these are my watches Watch : : Master_WorkBook : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\bptags.xls" : String : Exwork Watch : : Master_WorkSheet : "ccu3" : String : Exwork Watch : : Secondary_WorkBook : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\mytemp.xls" : String : Exwork Watch : : Secondary_WorkSheet : "template" : String : Exwork Watch : : FileSaveName : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\B-4800-E-4419T.xls" : String : Exwork.RetrieveEXC Edited May 24, 2012 by btraemoore Quote
btraemoore Posted June 19, 2012 Author Posted June 19, 2012 (edited) just to update, this is the working code ' ' work done in excel ' Sub excelwork() Dim i As Integer, n As Long, c As Long c = 8 Dim CurrentItem As String Dim pause As Boolean Dim match As Variant Dim NewSheetName As String NewSheetName = Dwg_Name & "assets" 'set a count for items in collection For i = 1 To EOC Cur_TxtSTR = text_coll(i) MasWorksheet.Activate MasWorksheet.cells(1, 3).Activate 'set a count for items in excel spreadsheet For n = 1 To 876 CurrentItem = MasWorksheet.cells(n, 3).Value 'compare collection item to each excel item, until we find our match If Cur_TxtSTR = CurrentItem Then MasWorksheet.Rows(n).Select ' select the row MasWorksheet.Rows(n).Copy ' copy the row secWorksheet.Activate secWorksheet.cells(c, 1).Activate secWorksheet.paste ' paste the row in the new sheet secWorksheet.cells(c, 10).Value = Dwg_Name ' insert the drawing name in new sheet c = c + 1 End If Next n Next i secWorksheet.Copy ' copy the new sheet ExcelServer.activeworkbook.sheets("template").Name = NewSheetName ' set the new sheet name FileSaveName = ExcelServer.Application.GetSaveAsFilename _ (InitialFileName:=Dwg_Name & ".xls", Title:="Save As") ' choose where we're going to save it If FileSaveName = "False" Then ' error handleing MsgBox "File not Saved, Actions Cancelled." Exit Sub Else ExcelServer.activeworkbook.SaveAs FileSaveName ' save it ExcelServer.activeworkbook.Close ' close it End If ExcelServer.Application.DisplayAlerts = False ' hide unwanted alerts ExcelServer.workbooks("bptags.xls").Close ' close the work book ExcelServer.Quit ' quit excel set_to_nil ' function to reset object variables to nothing End Sub This is my blog, fell free to drop by and look or correct http://showyourcode.blogspot.com/ Edited June 21, 2012 by btraemoore Quote
