Insert a point at each vertex of selected 2D or 3D polyline!
Margusrebase
Hei,
Gould anyone help me to make autolisp like this? I want add points automatically to 2d or 3d polyline vertex! I have autolisp that can draw circles but not points!
Best regards!
Margus
test.lsp
  • Replies 24
  • Margusrebase
    7
  • ronjonp
    5
  • Grrr
    5
  • Lee Mac
    3
(defun C:test ( / L )
 (and
   (setq L (car (entsel "\nPick Polyline: ")))
   (setq L (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget L)))
   (mapcar '(lambda (x) (entmakex (list '(0 . "POINT") x))) L)
 ); and
); defun
(vl-load-com)(princ)
Try again (I've forgot to entget) , btw this should be faster:
 (if (setq L (car (entsel "\nSelect polyline: ")))
   (foreach x (entget L)
     (if (= 10 (car x))
); defun
Yeah - I've forgot that there were "VERTEX" entities (since I work only in 2D):
; entmakes points on vertices of lines/polylines
(defun C:test ( / foo SS i )
 (defun foo ( e / enx typ )
   (setq enx (entget e)) (setq typ (cdr (assoc 0 enx)))
   (cond
     ( (= "LINE" typ)
       (entmakex (list '(0 . "POINT") (assoc 10 enx)))
       (entmakex (list '(0 . "POINT") (cons 10 (cdr (assoc 11 enx)))))
     ( (= "LWPOLYLINE" typ)
       (foreach x enx
         (if (= 10 (car x))
     ( (= "POLYLINE" typ)
       (while (and (setq e (entnext e)) (= "VERTEX" (cdr (assoc 0 (setq enx (entget e))))))
   ); cond
 ); defun foo
 (if (setq SS (ssget '((0 . "*LINE"))))
   (repeat (setq i (sslength SS))
     (foo (ssname SS (setq i (1- i))))
); defun C:test
(defun c:foo (/ _point c el p s typ)
 ;; Code updated to account for 2d & 3d lists & lines
 (defun _point (p) (entmakex (list '(0 . "POINT") '(8 . "POINT") (cons 10 p))))
 (if (and (setq s (ssget '((0 . "*polyline,line,circle")))))
   (foreach pl	(vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
     (cond ((= "CIRCLE" (setq typ (cdr (assoc 0 (setq el (entget pl))))))
     (_point (cdr (assoc 10 el)))
    ((= "LINE" typ) (_point (cdr (assoc 10 el))) (_point (cdr (assoc 11 el))))
    ((setq p (vlax-get (vlax-ename->vla-object pl) 'coordinates))
     (setq c (= "LWPOLYLINE" typ))
     (while p
       (_point (if c
		 (list (car p) (cadr p))
		 (list (car p) (cadr p) (caddr p))
       (if c
	 (setq p (cddr p))
	 (setq p (cdddr p))
(vl-load-com)
Edited by ronjonp
Nice one Ron,
I thought about the 'Coordinates approach aswell, but my next thought was that the list would require "group by 3" processing - after seeing your code now I know that this "grouping" could be avoided.
Nice one Ron,
Cheers! :)
(defun c:foo (/ p s)
 (if (and (setq s (ssget '((0 . "*polyline")))))
     (while p
   (entmakex (list '(0 . "POINT") '(8 . "POINT") (cons 10 (list (car p) (cadr p) (caddr p)))))
   (setq p (cdddr p))
(vl-load-com)
Ron, I think (caddr p) will point to the x-coordinate of the successive vertex for an LWPolyline; also note that (cons 10 (list ... )) is the same as (list 10 ... )
Ok, I'll stop my nit-picking now :ouch:
Here's another way:
(defun c:pvtx ( / e i p s )
   (if (setq s (ssget '((0 . "*polyline"))))
       (repeat (setq i (sslength s))
           (setq e (ssname s (setq i (1- i))))
           (repeat (- (setq p (fix (+ (vlax-curve-getendparam e) 1 1e-8))) (logand 1 (cdr (assoc 70 (entget e)))))
               (entmake (list '(0 . "POINT") (cons 10 (vlax-curve-getpointatparam e (setq p (1- p))))))
(vl-load-com) (princ)
FWIW, this:
Could also be written:
(+ (setq p (fix (+ (vlax-curve-getendparam e) 1 1e-8))) (vlax-get (vlax-ename->vla-object e) 'closed))
But the latter will likely be slower due to vlax-ename->vla-object.
Edited by Lee Mac
You are correct sir :) .. did not even think about 2d points being reported on lwpolylines! Good catch!
