mcad88 Posted January 20, 2010 Share Posted January 20, 2010 Hi I am using Autocad 2009 with xp pro 32bit. Using ALIGN command in a drawing, when I type in the command and pick the two points of the object to align, the object either scales down or scales up depending on the object I want to align with. I will be grateful for your help, this is my first time on the forums for help. Thanks in advance. Mcad88 Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 20, 2010 Share Posted January 20, 2010 You should get an option on the command line to accept or reject scaling. Quote Link to comment Share on other sites More sharing options...
mcad88 Posted January 20, 2010 Author Share Posted January 20, 2010 Thanks for getting back to me, unfortunately the accept or reject scaling cannot be seenn on the command line Quote Link to comment Share on other sites More sharing options...
lpseifert Posted January 20, 2010 Share Posted January 20, 2010 This is the command line history when I use Align, using two points Command: ALIGN Select objects: 1 found Select objects: Specify first source point: ENDP,INT of Specify first destination point: ENDP,INT of Specify second source point: ENDP,INT of Specify second destination point: ENDP,INT of Specify third source point or : Scale objects based on alignment points? [Yes/No] : If you use three points, you don't get an option for scaling Quote Link to comment Share on other sites More sharing options...
mcad88 Posted January 20, 2010 Author Share Posted January 20, 2010 lpseifert Thanks for you quick response, must say all the response I had has been great. I used align then used only one align command, this helped. Thanks again Mcad88 Quote Link to comment Share on other sites More sharing options...
