Editing Already Uploaded 3D Warehouse Models??
transonik21
Is there a way to edit a model I already have uploaded into the 3D Warehouse without losing all my data associated with that model? For example, the # of views, the downloads, and my descriptions.
Hi, I have actually done this before, when i entered the sketchup 3d challenge. But there is still a case that you might loose the data.
there are 2 ways you can do this:
1. If you still have the original file, you can always re-upload the edited file with the same file name. it should be able to recognize which model it is (at least in my case, it did). Also you should be logged in as the same user.
2. If you have deleted the file from hour computer, you can always download and edit it in sketchup.
just click the edit drop down menu (which is located just below the title of your model) and select edit in sketchup. 3d models1.jpg
