Construction line vs Regular construction line AutoCAD 2010
Hi,
Is there a way for me to get,customize or import the regular linear construction line? for example: if when i need i just click on the construction line tool and it will work either vertical or horizaltal, i used to be able to do in different version of cad but not on this 2010 autocad that i have. when i click then window pop up and show me all type of const lines i don't want all. Greatly appreciate any suggestion thanks.
That dialog is specific to Mechanical pack (and probably other vertical products); if you want the behavior of Vanilla’ AutoCAD, then try to use XLINE command instead.
Hi, MSasu, as you can see on the attached pic, top right corner, i am on Xline command mode. unless you mean other Xline, if that is the case, where can i get it? thanks
