Autocad dwg to pdf by script with batch file help....
bmartinez
I need a script that will convert multiple DWG files to ONE single PDF file,I found one that does convert the dgw file but to single pdfs , im also having some issues with DWG files that are "read only" wont convert them but all my files i need to convert to pdf are READ ONLY.
Options:
1. You need to use the publication, team _publish
2. Open the drawing and start the normal printing. Select the print area, print settings, specify the printer and print.
Or do you have many frames in one model?
