When two flow lines cross eachother they make a break automatically, but it is so small you can't see it unless I zoom way in. How do you change this? THanks in advance.
Printable View
I am not sure if you found a solution to this problem, but here it is.
Go to the project manager and right click, then select properties. This will take you to project setup.
On the left pane, Expand the P&ID DWG settings, then select line settings. On the top of the right pane, you should see a value for gap/loop width. Adjust this to whatever suits your needs.
Hope I was able to help.
