Insert a block at multiple points or lines and scale
grouch19
  • Replies 22
  • grouch19
    10
  • BIGAL
    7
  • Lee Mac
    2
  • eldon
    1
Posted Images
  • 4 years later...
Dear Lee
when i run the code its showing
; error: extra cdrs in dotted pair on input
(defun c:insblk ( / blk cmd dwg ent enx idx lst scl sel )
   (setq blk "Manhole") ;; Block Name
   (cond
       (   (not
               (or (tblsearch "block" blk)
                   (and (setq dwg (findfile (strcat blk ".dwg")))
                           (setq cmd (getvar 'cmdecho))
                           (setvar 'cmdecho 0)
                           (command "_.-insert" dwg nil)
                           (setvar 'cmdecho cmd)
           (princ (strcat "\nBlock \"" blk "\" not found or could not be defined."))
       (   (setq sel (ssget "_:L" '((0 . "POLYLINE") (-4. "&=")(70 . (-4 . "<NOT")(-4 . "&=")(70 . 1)(-4 . "NOT>"))))
           (repeat (setq idx (sslength sel))
               (setq ent (entnext (ssname sel (setq idx (1- idx))))
                     enx (entget ent)
                     lst nil
               (while (= "VERTEX" (cdr (assoc 0 enx)))
                   (setq lst (cons (cdr (assoc 10 enx)) lst)
                         ent (entnext ent)
                         enx (entget  ent)
               (if (= 3 (length lst))
                       (if (apply '< (setq scl (mapcar 'distance lst (cdr lst))))
                           (setq lst (reverse lst)
                                 scl (reverse scl)
                       (if (minusp (sin (- (angle (car lst) (caddr lst)) (angle (car lst) (cadr lst)))))
                           (setq lst (vl-list* (cadr lst) (car lst) (cddr lst)))
                       (if (entmake
                               (list
                                  '(000 . "INSERT")
                                   (cons 002 blk)
                                   (cons 010 (car  lst))
                                   (cons 041 (car  scl))
                                   (cons 042 (cadr scl))
                                   (cons 050 (angle (car lst) (cadr lst)))
                           (entdel (ssname sel idx))
