Results 1 to 7 of 7
    Full Member
    AutoCAD 2014
    Sep 2015
    64
    Default How to increase space between objects?
    I have a row of rectangles, spaced evenly and I need to increase the spacing. How do I set the space between each of them to be a specified amount?
    AutoCAD 2013
    Nov 2011
    5,993
    Typically the ARRAY command would be used to generate them, which makes adjusting spacing really easy.
    If they are not an ARRAY, it is much more tedious.
    You may want to erase them, then use ARRAY, it will save you a lot of time.
    Forum Newbie
    Architectural
    AutoCAD 2017
    Feb 2017
    3
    Quote Originally Posted by Dadgad View Post
    Agreed, use the ARRAY command, when it comes time to set the "spacing", be sure to add the "space" to the width of the object. ARRAY only "sees" the gap between a point, not the space between the object. So if you have 1x1 squares and you want 20 with a 3" gap between them, you'll use the spacing of 4" to get it.
    Full Member
    AutoCAD 2014
    Sep 2015
    64
    I tried out Array and it seems fine; thanks for the idea.
    The Help doesn't say, does it support expressions, like progressively increasing the spacing?
    E.g.:
    Let spacing between O1 (1st object in the array) and O2 be S; then, between O2 and O3 it would be (2xS); between O3 and O4: (3xS); and so on.
  5. #5
    AutoCAD 2013
    Nov 2011
    5,993
    Quote Originally Posted by rlcad View Post
    E.g.:
    No it does not, that sounds like a good application for a lisp.
  6. #6
    Forum Newbie
    bluessdjs's Computer Details
    personal computer
    Construction
    AutoCAD 2014
    Mar 2017
    2
    newbie learning cad
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Quote Originally Posted by bluessdjs View Post
    newbie learning cad
    Perhaps you should get some training then.
  1. Objects appear in model space only
    By Hobblenobble in forum AutoCAD Drawing Management & Output
    Last Post: 10th Feb 2016, 06:54 pm
  2. Send all objects on certain layer from paper space into model space.
    By gaddyzt in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2014, 06:51 pm
  3. Copying objects from one layout space to another
    By ADAM'S_APPLE in forum AutoCAD Drawing Management & Output
    Last Post: 11th Oct 2011, 04:20 pm
  4. Moving objects from paper space to model space
    By schneeflocke in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2009, 09:19 pm
  5. cant change the objects in paper space!
    By kayab in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2006, 07:43 pm
