SOliver Posted March 7, 2017 Share Posted March 7, 2017 Hi all I've recently been having another attempt at installing the dotNet API for AutoCAD. As my previous attempt I installed VS 2015 and the AutoCAD SDK. Once this is complete you are meant to open VS and select the templates from the list. However, in all attempts the templates have not appeared in the New Project template lists for either vb vc# or c++. There doesn't appear to be an opportunity for me to be making a mistake as the SDK is just a self extracting exe. Is there a way for me to add these templates or does anyone have any idea of why they haven't turned up. Note: The AutoDesk template sub label doesn't exist in my VS project templates list. Quote Link to comment Share on other sites More sharing options...
zmandic Posted May 2, 2017 Share Posted May 2, 2017 HI, To get templates in VS2015 you need to install ObjectARX wizard http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112 I have also VS2015 and AutoCAD 2015 and i downloaded ObjectARX2018 and works for me with VS2015 and AutoCAD 2015. But when you creating new project its necessary to choose .NET Framework 4.6 and then AutoCAD 2018 CSharp plug-in will be shown. With this code you can try if it's working. using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; [assembly: CommandClass(typeof(AutoCAD_CSharp_plug_in2.MyFirstProgram))] namespace AutoCAD_CSharp_plug_in2 { class MyFirstProgram { [CommandMethod("AdskGreeting")] public void AdskGreeting() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Starts a new transaction with the Transaction Manager using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table record for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[blockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; /* Creates a new MText object and assigns it a location, text value and text style */ using (MText objText = new MText()) { // Specify the insertion point of the MText object objText.Location = new Autodesk.AutoCAD.Geometry.Point3d(2, 2, 0); // Set the text string for the MText object objText.Contents = "Greetings, Welcome to AutoCAD .NET"; // Set the text style for the MText object objText.TextStyleId = acCurDb.Textstyle; // Appends the new MText object to model space acBlkTblRec.AppendEntity(objText); // Appends to new MText object to the active transaction acTrans.AddNewlyCreatedDBObject(objText, true); } // Saves the changes to the database and closes the transaction acTrans.Commit(); } } [CommandMethod("_inputCoord")] } } Quote Link to comment Share on other sites More sharing options...
