help with grips and object points
sandiegophil
Hello,
I have a file with a block made of some simple lines and arcs. When I view it on screen, the lines and arcs do not meet at common endpoints. When I edit with the grips, they grip the points correctly but the grips do not match the 'visual' endpoints. Additionally, everything plots perfectly. I have set viewres to the max value with no results. I am ending up with 'x's at the corners.
What settings am I overlooking?
Thanks,
Phil
a fantastic idea, unfortunately the boundary of the block consists of 2 lines and 2 arcs that are already joined and closed.
thank you for replying
RESOLVED-
Thanks to all for your suggestions and assistance. I recreated the boundary and was able to get the 'appearance' I wanted. Strange way to get it though, I made sure the block object entities were all created clockwise and that seemed to fix the issue. Have any of you run into the same situation??
Regards,
Phil
