catphe10 Posted March 8, 2017 Share Posted March 8, 2017 Hello, I have a drawing with approximately 4400 points in it. and a file folder with the same number of files. What i am looking for is a lisp routine that will use the point description and then create a hyperlink to the file in the folder with the name that is the same as the description. So if i have a point thats description is 43804152000, the lisp routine would go to the folder where all the hyperlink files are saved and hyperlink to the file named 43804152000. I have zero knowledge in lisp routines and would appreciate any help! Thanks, Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted March 8, 2017 Share Posted March 8, 2017 Since 'normal' points do not have a description, are you perhaps referring to Cogo points? Quote Link to comment Share on other sites More sharing options...
catphe10 Posted March 8, 2017 Author Share Posted March 8, 2017 Yes, they were brought in from a surveying data collector. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted March 9, 2017 Share Posted March 9, 2017 I am afraid I can't help you then since I use BricsCAD instead of AutoCAD. It may help members who do use AutoCAD but not Civil 3D, if you post a dwg with a couple of those Cogo points. Quote Link to comment Share on other sites More sharing options...
