Results 1 to 6 of 6
    Forum Newbie
    Architectural
    AutoCAD 2017
    Mar 2017
    2
    Default Hatching question
    I'm putting down a polyline to set up the perimeter for a proposed hatch. I encounter a curve. Do I stop, create the curve, and then join the two separate objects? Sometimes there situations where I don't want to use 'pick points'.
    AutoCAD 2013
    Nov 2011
    5,992
    Welcome to CADTutor Newbie.
    When in doubt, read the commandline prompts...choose the Arc option, and the polyline command will start generating arcs instead of lines, from the last vertex forward.
    When you have completed doing the arc or arcs, choose the Line commandline option, and keep on going.
    In this way you generate a continuous Polyline, when you are about to create the last segment, choose Close.
    Unless you use an available commandline option to change it, it will continue to create segments of the same ilk as the previous one, but you can change it whenever you need to.
    Additionally, after the fact, should you need to, you can use the right click options available on the center grip of any polyline segment to convert an arc to a line, or a line to an arc.
    Forum Newbie
    Architectural
    AutoCAD 2017
    Mar 2017
    2
    Excellent assist, thanks!
    AutoCAD 2013
    Nov 2011
    5,992
    Happy to help!
    As far as I am concerned, I greatly prefer working with CLOSED polylines, when appropriate, which is one reason why using the CLose option for the last segment of your polyline is a good idea. As with any other segment, if your last one should be different (meaning arc or line) than the previous one, just enter the appropriate commandline option, A or L, before using the CLose option.
  5. #5
    Senior Member dtkell's Avatar
    dtkell's Computer Details
    Win7
    Intel I5 4670
    16mb
    Civil
    dtkell's Discipline Details
    Drafter/Designer
    Civil
    AutoCAD 2014
    Dec 2006
    San Diego, CA, USA
    148
    Quote Originally Posted by Dadgad View Post
    ... when you are about to create the last segment, choose Close. ...
    My personal view, FWIW, make the last segment and then close. This way, that last segment is actually there. If you do close for that last segment, and then sometime you PEdit and open, you will see that segment is not there.
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by dtkell View Post
    Which is an indicator that the polyline is not closed. If it's there, the polyline can appear closed when it is not.
    Drafting is a breeze.
  1. Cross-hatching within Inventor 2010 drawings question
    By Hopinc in forum Autodesk Inventor
    Last Post: 1st Dec 2014, 09:36 pm
  2. Hatching Question
    By tennis4you in forum AutoCAD General
    Last Post: 15th Jun 2011, 03:49 am
  3. Replies: 5
    Last Post: 25th Jul 2005, 02:28 pm
  4. Hatching question
    By bill in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2005, 09:25 pm
  5. Hatching question on Autocad 2000
    By Jerry98vert in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jul 2004, 04:54 pm
