How to create a pattern of extruded sheet (bulkhead) that fit in a varying shell?
dimasmr21
I want to create a series of bulkheads or diaphragms inside a non uniform cross sectional shell.
I design a leg of a RTG (rubber tired gantry), this leg has a non uniform cross section (in x and z direction) reinforced by series of diaphragms and stiffeners (see the third picture).
I tried vary sketch but its useless.
p.s. i dont have the license. I use licensed solidworks at the company where i intern
Any help or hint will be enough. Thank you so much.. :):):):)
  • 2 weeks later...
i cant see the picture either and yes Vary Sketch is fairly useless except for very specific applications. Like a trapezoidal cutout and rubs varying their length to fill it.
What you probably want to do, just based on your description, is either a sketch(sketch point) based pattern or a curve driven pattern. The curve can be in 2d or 3d, and can be created by slicing(intersection curve) inside of the non-uniform cross section. Then you can pattern features or bodies along it.
