Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Dwg to pdf
    Forum Newbie
    P&ID
    P&ID 2015
    Jan 2017
    7
    Unhappy Dwg to pdf
    hi guys,
    I have found a desired lisp routine to convert DWG TO PDF after long googling and made little changes to suit my requirement. Here problem is this routine converts each DWG at a time but I have to convert around 100 dwgs to pdf. somebody can help me to convert this routine to proceed as batch converter.
    Forum Newbie
    P&ID
    P&ID 2015
    Jan 2017
    7
    sorry forgot routine
    (defun c:A3_BIGENCOLOUR_PDF (/)
    (setvar "cmdecho" 0)
    (setq cur_plottransparencyoverride (getvar "PLOTTRANSPARENCYOVERRIDE"))
    (setvar "PLOTTRANSPARENCYOVERRIDE" 2)
    (setq cur_space (getvar "ctab"))
    (command "zoom" "Extents")
    (setq filename (getfiled "Enter PDF file name" "" "pdf" 1)) ;;;https://forums.autodesk.com/t5/visua...p/td-p/3060536
    (command "-plot" ; Start plot command
    "yes" ; Detailed plot configuration?
    (getvar "ctab") ; Get a layout name
    "DWG To PDF.pc3" ; Enter an output device name GEBRUIK DUBBEL \\ VIR UNC PARTHS
    "ISO full bleed A3 (420.00 x 297.00 MM)" ; Enter paper size
    "Millimeters" ; Enter paper units
    "Landscape" ; Enter drawing orientation
    "No" ; Plot upside down?
    "window" ; Enter plot area
    "1:1" ; Enter plot scale
    "Center" ; Enter plot offset (x,y)
    "Yes" ; Plot with plot styles?
    "prop.ctb" ; Enter plot style table name or
    "No" ; Plot with lineweights?
    "No" ; Scale lineweights with plot scale?
    "No" ; Plot paper space first?
    "No" ; Hide paperspace objects?
    filename
    ;;; "No" ; Write the plot to a file
    "Yes" ; Save changes to page setup
    "Yes" ; Proceed with plot
    (setvar "cmdecho" 1)
    (setvar "PLOTTRANSPARENCYOVERRIDE" cur_plottransparencyoverride)
    Senior Member SunnyTurtle's Avatar
    SunnyTurtle's Computer Details
    Win 7 64 bit
    Civil
    SunnyTurtle's Discipline Details
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2016
    Apr 2011
    Sydney Australia
    150
    I know this is not exactly what you are looking for but have you looked into PUBLISH
    https://knowledge.autodesk.com/suppo...n-AutoCAD.html
    Forum Newbie
    P&ID
    P&ID 2015
    Jan 2017
    7
    sunny,
    I know publishing but instead of publish I want to use routine.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,422
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  6. #6
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2017
    Dec 2010
    Tallahassee, FL USA
    587
    I have Page Setups for both PDF or Plotter in every Layout for all my Templates. When needed I'll toggle Page Setups for all layouts at between PDF and Plotter with a lisp routine.
    To plot a single layout I have a macro in my Ribbon
    Code:
    ^C^C-Plot;No;;;;No;No;Yes
    that sends it to the plotter with one click.
    With a structured approach AutoCAD is easy. Are you seriously still picking window corners every time you plot?
  7. #7
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    251
    Quote Originally Posted by naren View Post
    sunny,
    I don't see any better way then using PUBLISH for this. Since you want the drawings to plot to PDF. PUBLISH is perfect for that (has an checkbox to override the plotter set in the layout)
  8. #8
    Super Member prodromosm's Avatar
    AutoCAD 2014
    Jul 2010
    582
    Hi i use this lisp
    Code:
    ;                          Layouts To PDF                      ;
    (defun C:laytopdf ( / cmd )
      (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0)
      (foreach Layout (layoutlist)
        (command "_.-PLOT"
          "No"                                        ; Detailed plot configuration? [Yes/No] <No>: No
          Layout                                      ; Enter a layout name or [?] <Layout1>:
          ""                                          ; Enter a page setup name
          "DWG To PDF.pc3"                            ; Enter an output device name or [?] <DWG To PDF.pc3>:
          (strcat (getvar "DWGPREFIX") Layout ".pdf") ; Directory to save
          "No"                                        ; save changes to page setup?
          "YES"                                       ; proceed with plot?
        ); command
      ); foreach
      (vla-put-StyleSheet(vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object))) "monochrome.stb" )
      (setvar 'cmdecho cmd)
    ); defun C:test
  9. #9
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2017
    Dec 2010
    Tallahassee, FL USA
    587
    Quote Originally Posted by prodromosm View Post
    Hi i use this lisp → Layouts To PDF
    I like that, it's simple!
  10. #10
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    838
    Hi i use this lisp
    The formatting looked familiar
Tags for this Thread
