Results 1 to 2 of 2
    Forum Newbie
    Construction
    not applicable
    Mar 2017
    1
    Smile About changing dimension and font style
    Hi, I am new to this forum and just start learning autolisp. I am converting revit to autocad dwg format, but in the dwg I found that there are many duplicated dimension and font style...now my situation is: if I have 10 dimension in a revit view, then export to dwg, I will have 10 dimension style named 2mm_RomanS, 2mm_RomanS_1, 2mm_RomanS_2 etc....how can I use autolisp to find all of them, and then change them to 2mm_Romans? and then delete the rest style.
    Thank you!
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    I use version 4.2 MergeTextStyles.lsp by T.Willey. I've been using it since version 3.0 and it's a nice dialog box routine that makes it easy-peasy!
    https://www.theswamp.org/index.php?t...5812#msg575812
    I'd start with using the Purge command to see if that helps with the multiple dimension styles.
  1. Dimension font resizing to last edited dim style
    By joneser99 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Jun 2012, 01:08 pm
  2. Changing Font Style of a Room Tag
    By Marc5 in forum AutoCAD General
    Last Post: 1st Sep 2010, 05:35 pm
  3. Changing font face/style at once
    By jay-d in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2010, 10:26 pm
  4. Friday Teaser - Font style changing in text style
    By feargt in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Jul 2010, 09:39 am
  5. logo font in template affecting dimension style
    By legend in forum AutoCAD Beginners' Area
    Last Post: 17th Jan 2008, 11:00 pm
Tags for this Thread
