Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    Mechanical
    AutoCAD 2010
    Mar 2017
    6
    Default AutoLisp Dim Command
    I type the following command: (command "dim" "scale" "0.06" ""). AutoCAD accepts the command and tells me I must input "exit" to exit the command. I do this on the command line and it works fine, but I don't know how to either incorporate the "exit" command into the above command or follow the above command with a second AutoLisp command executing the "exit" command.
    Please Help if you can!
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2017
    Dec 2010
    Tallahassee, FL USA
    587
    Use (command "dim" "scale" "0.06" "" "")
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,457
    Or alternately use "_.DIM1" for the command
    -David
    R12 (Dos) - A2K
    Senior Member
    not applicable
    Jun 2016
    361
    Or:
    Code:
    (setvar 'dimscale 0.06)
    BricsCAD 16
  5. #5
    Forum Newbie
    Mechanical
    AutoCAD 2010
    Mar 2017
    6
    Thanks David. I used the suggestion from Roy043, i.e., (setvar 'dimscale 0.06), which worked beautifully.
  6. #6
    Forum Newbie
    Mechanical
    AutoCAD 2010
    Mar 2017
    6
    Thanks tombu. That did not work, but the suggestion from Roy_043, (setvar 'dimscale 0.06), did work.
  7. #7
    Forum Newbie
    Mechanical
    AutoCAD 2010
    Mar 2017
    6
    Thanks David. I tried the "_.DIM1" - it opened the dialog box, which I did not know how to do (thanks) but was not what I wanted to do.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,457
    Quote Originally Posted by Nick1940 View Post
    Code:
    (command "_.DIM1" "_Scale" 2)
    Should work. No need for any closing CarriageReturns -David
    R12 (Dos) - A2K
  9. #9
    Forum Newbie
    Mechanical
    AutoCAD 2010
    Mar 2017
    6
    Thanks again Dave. I tried it but this time it didn't even open the dialog box. But that's OK because the setvar command worked great. I am going to use the set var command to change the osnap setting as well. -Nick
  10. #10
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    8,907
    If you use this simple Dumpit and pick a dim you will expose all the variables that can be set and there are a lot.
    Code:
    (vlax-Dump-Object (vlax-Ename->Vla-Object (car (entsel "pick an object"))))
  1. Custom AutoLISP command
    By geo1595 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 9th Oct 2015, 11:21 am
  2. AutoLISP Using FeatureElevsFromSurf COMMAND
    By srv560 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jan 2015, 11:22 am
  3. How can i use the (array ) command in Autolisp ???
    By سبع الليل in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2013, 06:35 pm
  4. Autolisp instead of View command
    By Tharwat in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2010, 03:41 pm
  5. Diesel command in AutoLisp
    By David Bethel in forum Tutorials & Tips'n'Tricks
    Last Post: 2nd May 2004, 02:04 pm
