Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 37
  1. #21
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    Unhappy
    I would check the hardware acceleration setting first. Change and test to see if it makes a difference. If that doesn't solve the problem then I would use the "Reset Settings to Default" option found on the Control Panel under the version of AutoCAD you intend on running.
    I would not update the drivers at this time.
    If you want to give the C++ libraries option a try then go ahead. What do you have to lose?
    To make matters worse, both of my Autocads get stuck at loading and don't start at all. . This happens regardless of whether I have have my internet on or off, my antivirus on or off.
    Installed a trial of Autocad 2018. Ran for the first time. Drew a few lines and a rectangle. Closed it. Started it again. Same damn issue. Screen stuck at loading with silver line animation sliding as usual. To be on safer side I did not migrate any settings and started as a fresh clean slate.
    This seems to be issue in the window registry or some system folder that messes up with any version of autocad.
  2. #22
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    I'm not sure what you really expected to happen.
  3. #23
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    I was hoping that at least 2018 would start up fast...
  4. #24
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    It does if your system isn't all messed up. You need to fix the problem you have before you do anything else. Loading a newer version of the same program wasn't going to solve the problem as you found out.
    Are you going to try any of the other options discussed previously?
  5. #25
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Have you tried complete uninstall then a reinstall?
  6. #26
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    Quote Originally Posted by SLW210 View Post
    No, I just did a regular uninstall from the control panel everytime. I must do a clean full wipe out of Autocad and then see...
  7. #27
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    I uninstalled 2012 yesterday. After that I installed windows 10 software repair tool. It ran for an hour and a half. Today I checked. The startup time of Autocad is now reduced to 5 minutes from 20 minutes now. I'm still in a dilemma whether I should wipe off Autocad files after uninstall to further reduce the startup time.
  8. #28
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    Rock1 I run a laptop with I3 and only 8Gb of ram win 10 so it takes about 1+ min to start, but starts every time. Anyway if you google "Remove Autocad" there is method information available to really clean all of Autocad from your PC not just Uninstall.
  9. #29
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    Quote Originally Posted by BIGAL View Post
    Yeah. I"ll have to do a clean wipe. These long load times are really irritating..
  10. #30
    Senior Member
    AutoCAD 2012
    Sep 2011
    137
    Did a clean wipe out of AUtocad. My startup time is now 3-4 minutes. Sometimes it takes 2 minutes.
  1. AutoCAD 2013 - Deleting / saving EXTREMELY slow compared to 2012
    By Ixath in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 11th Jan 2016, 03:35 pm
  2. AutoCAD 2012 Running Slow...
    By iamthemilk in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2014, 03:50 pm
  3. AutoCAD LT 2012 running slow, hardly using any memory
    By plrob in forum AutoCAD Beginners' Area
    Last Post: 13th Jul 2012, 06:02 pm
  4. Lisp in Startup Suite Causing Slow Save and Close - Cad2012
    By pardavis in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2012, 12:51 pm
  5. Autocad 2012 seems slow to load and crashes often
    By Abbyjay in forum AutoCAD General
    Last Post: 27th Aug 2011, 02:19 am
