samifox Posted March 15, 2017 Share Posted March 15, 2017 hi using acad 2019, when i draw 2d the lines are getting Z and it impossible to perform some action like trim,extend,fillet. is there an option to prevent lines i create and snap to have Z value? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 15, 2017 Share Posted March 15, 2017 Yes, you can have it set to replace the Z value with current elevation. There is a button available for the status bar, or whatever they are calling it now. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 16, 2017 Share Posted March 16, 2017 In OPTIONS, look at the lower left corner on the DRAFTING tab. Sounds like what you want to check is 'Replace Z value with current elevation'. If you are using Dynamic UCS, then consider the bottom option. These checkboxes control the OSNAPZ system variable, as described in the screenshot from the SYSVDLG. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 16, 2017 Author Share Posted March 16, 2017 In OPTIONS, look at the lower left corner on the DRAFTING tab.Sounds like what you want to check is 'Replace Z value with current elevation'. If you are using Dynamic UCS, then consider the bottom option. These checkboxes control the OSNAPZ system variable, as described in the screenshot from the SYSVDLG. it seems like it does it. thanks a lot! Quote Link to comment Share on other sites More sharing options...
