cutout viewports whithin a viewport
samifox
hi
using acad 2010
i want to create a viewport, and then draw rectangles around some portions in that viewport, and have those squares to become new viewports.
how?
You can use VPCLIP for that. Run command -> Select original viewport -> Select new (closed) polyline -> New viewport has been made with same properties as the main one.
hi
using acad 2010
how?
viewports inside viewports - 3 methods
1) First draw a rectangle that will be the size wanted for the big
viewport. Use the Region command and make that a region, now use the
Mview command, Object option and pick the region. Adjust the view in
that viewport accordingly.
Now draw circles or polygons, etc. that will represent the smaller
viewport(s). Place those where you will want them. Use the Region
command again. Use the subtract command and pick the large region
then the smaller one(s). Now draw the circles again in the blank
space, use the Mview command, Object option. Adjust those viewports
accordingly. Because these are regions now you won't be able to edit
them like a normal viewport, IE: grip stretch, etc.
2) In MS use wipeout to hide the area you want another VP to reside.
Now in PS use MVIEW and grab the opposite corners of the wipeout.
3) In PS you can draw a continuous pline with a large rectangle and
then move into the center and draw a smaller rectangle, all in the
same pline command. You will have two plines one of top of the other
going to the smaller rectangle but that is ok because it won't show.
Now use the MVIEW command and use Object option. Now use MVIEW again
to define the smaller viewport grabbing the opposite corners of the small
rectangle. Or after drawing the closed pline, create an mview, then
use the CLIP command and pick on the viewport and then the closed
pline.
3a) See drawing that explains how to have two overlapping viewports where you
can stretch the smaller one and have both vp's adjust at the same time.
viewport in viewport 2007.dwg
