Results 1 to 3 of 3
    Forum Newbie
    Architectural
    HRICHEY's Discipline Details
    Architectural
    Residential
    Architecture 2017
    Mar 2017
    Ft Worth, TX
    1
    Angry Smart Wall Thickness not Displaying while drawing
    Hello! An odd and irritating problem. When drawing my smart walls the thickness is not displaying making it difficult to know which side of the line the wall will appear on. Does anyone know what setting I need to change tot fix this?
    << This is how it SHOULD look, with the thickness displaying.
    Instead I get only a single line, and the wall comes in after I complete the command.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    I moved your thread to the Architecture & ADT Forum since it appears specific to Architecture.
    AutoCAD 2013
    Nov 2011
    5,986
    Welcome to CADTutor HRICHEY.
    I don't use Architecture, but I am guessing that the AEC object created is very much like the Polysolid functionality in Autocad Vanilla.
    Check in Settings, at the commandline, or in Properties, and set the JUSTIFICATION howeverr you prefer.
    Come to think of it, assuming that you are reading the commandline prompts, as you should be, and that there is a SETTINGS or JUSTIFICATION option, better to set it there. If you change it in Properties, you will only be changing the justification of that particular object, as opposed to the Default behavior for the command.
  1. Red and yellow vectors displaying on wall objects
    By WinePress in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Dec 2015, 08:30 pm
  2. Unit settup not working for Wall thickness!!!!!!!!!!!!!
    By Rahim Shaikh in forum Revit Architecture
    Last Post: 20th Dec 2014, 05:25 pm
  3. Importing Images + Wall Thickness
    By Tyler Durden in forum AutoCAD Beginners' Area
    Last Post: 23rd Dec 2013, 12:06 pm
  4. Plan showing wall thickness need section- anybody give lisp
    By mmsmurugan1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2012, 12:20 pm
  5. Gauge for Measuring Existing Wall Thickness
    By willwould in forum Catch All
    Last Post: 14th Jul 2009, 01:17 pm
Tags for this Thread
