Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    Electrical
    AutoCAD 2015
    Feb 2017
    14
    Default True Type Font For Searchable PDF
    I have a client who used Simplex.shx font all over their drawing package. Is there a way to use Simplex.ttf in a text style instead? I have read and searched all over and haven't gotten anything to work. When I go to my style manager Simplex_IV25 and SimplexIV_IV50 are the only true type fonts I can use of Simplex. They are wider and bolder than the regular version, which is not selectable. I would like to change the style using a script on my 300+ drawings so that when we convert to PDF it is searchable. I cannot use either Simplex_IV25 or Simplex_IV50 because the clients would notice and would complain, it would also throw alignment off. I am using ACADE 2015. Any other info needed, I can gladly give.
    Thanks
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    As far as I know, those TTF fonts with the same name as the SHX ones, are only there for display use in the MTEXT editor.
    R.K. McSwain
    CAD Panacea | twitter
    Junior Member
    Electrical
    AutoCAD 2015
    Feb 2017
    14
    So I am out of luck if I want to replace the text in the drawings so that their appearance doesn't change and they are searchable in PDF?
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    Why don't you just rename the .ttf file to simplex.ttf and / or get a ttf file that looks the same as the .shx file? I still prefer .shx because ttf has some funny display behaviour inside AutoCAD
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by bcarlso2 View Post
    It's been a while but I got limited results using Bluebeam to capture .shx fonts in the past. Maybe you could give it a trial.
    Drafting is a breeze.
  6. #6
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    AutoCAD's Swiss family of ttf's is pretty good. I've used their Swiss Lt BT for 95% of my text for at least a decade. It's much more compact and readable than any shx font. Copy any sentence and compare the two styles. I use title case for all my labeling and sentence case for notes. Civil drawing require conserving screen space, just not enough room on the paper any other way.
  7. #7
    Junior Member
    Electrical
    AutoCAD 2015
    Feb 2017
    14
    Quote Originally Posted by halam View Post
    If you mean change the .shx extension to .ttf of simplex, it doesn't work that way. The files do not store the same information and cannot simply go back and forth. I've never seen strange behavior from a ttf in CAD, but I would gladly trade that for the ability to search in a PDF since none of our customers use Electrical and our packages are 100's of pages long.
  8. #8
    Junior Member
    Electrical
    AutoCAD 2015
    Feb 2017
    14
    Quote Originally Posted by RobDraw View Post
    Some of my coworkers have it, but our company wont buy everyone a seat so I am stuck without. I may have them try it out.
  9. #9
    Junior Member
    Electrical
    AutoCAD 2015
    Feb 2017
    14
    Quote Originally Posted by tombu View Post
    I am almost always limited to the fonts and styles picked by the customer, but I will try to remember that if/when I do have some freedom in that area.
  10. #10
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I am almost always limited to the fonts and styles picked by the customer.
    Explain to the customer that if they want searchable PDFs, they should use TTFs.
  1. True Type Fonts Slowing Down Drawings
    By RobDraw in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jul 2017, 12:15 pm
  2. More true type font PDF plotting issues
    By robwalker24 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jun 2011, 01:17 pm
  3. True Type Fonts in AutoCAD (2008 to 2010)
    By CADnewbie in forum AutoCAD General
    Last Post: 31st Aug 2009, 06:54 pm
  4. True type font fills don't plot
    By jeronomous in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Aug 2007, 05:40 pm
  5. Unable to locate a true type font in CAD
    By hyposmurf in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Feb 2004, 02:43 pm
Tags for this Thread
