Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    Civil
    AutoCAD 2014
    Mar 2017
    12
    Default Put mass selected integers in ascending order starting from a given integer
    Hello,
    Let's say we have a group of integers as text in dwg.
    How would we put them in in ascending order by one(+1) starting from a given integer?
    Let me give an example to make it clear. Let's say we have the texts 1 2 5 5 5 8 9 11 11 15 and the given start integer is 6. We select them all together and the range in selection set is random. Let's say 5 2 8 15 1 5 5 11 9 11.
    Now, we want to put them in ascending order by one starting from number 6 replacing the "old" range with the new. In the end we must have this:
    6 7 8 8 8 9 10 11 11 12.
    That is 6(in place of 1), 7(in place of 2), 8(5), 8(5), 8(5), 9(, 10(9), 11(11), 11(11), 12(15). I hope it is clear.
    How would we do that in an efficient way?
    Thank you in advance,
    Kostas
    Junior Member
    Civil
    AutoCAD 2014
    Mar 2017
    12
    9(, = 9 ( 8 )
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    Consider the following code:
    Code:
    (defun renumberlist ( num lst )
        (setq lst (vl-sort lst '(lambda ( a b ) (< (atoi a) (atoi b))))
              num (1- num)
        (mapcar '(lambda ( a b ) (if (= a b) (itoa num) (itoa (setq num (1+ num))))) (cons nil lst) lst)
    Example:
    Code:
    _$ (renumberlist 6 '("5" "2" "8" "15" "1" "5" "5" "11" "9" "11"))
    ("6" "7" "8" "8" "8" "9" "10" "11" "11" "12")
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Quote Originally Posted by Lee Mac View Post
    Its impressive how fast you understand peoples tasks/problems.
  5. #5
    Junior Member
    Civil
    AutoCAD 2014
    Mar 2017
    12
    Thank you Lee Mac! I will try to import your code to my routine. If I don't manage, I will come back to you. (It's very possible because your coding is in much higher level than mine). Thanks!
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    Quote Originally Posted by Grrr View Post
    Thanks
    Quote Originally Posted by tsotzo View Post
    You're welcome tsotzo. My code demonstrates one possible method of ordering & renumbering a set of text values, however, assuming you are looking to then modify the text content, you will need to retain the entity name of the text object during the sorting & renumbering process - I'm happy to demonstrate this if you get stuck.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    Just for fun, here's a recursive function accepting a sorted list to produce the same result:
    Code:
    (defun renum ( num lst )
        (if lst (cons (itoa num) (renum (if (= (car lst) (cadr lst)) num (1+ num)) (cdr lst))))
    Example:
    Code:
    _$ (renum 6 (vl-sort '("5" "2" "8" "15" "1" "5" "5" "11" "9" "11") '(lambda ( a b ) (< (atoi a) (atoi b)))))
  8. #8
    Junior Member
    Civil
    AutoCAD 2014
    Mar 2017
    12
    That's right!
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    OK, I couldn't resist
    Code:
    (defun c:renum ( / a b i l n s x y z )
        (initget 4)
        (setq n (1- (cond ((getint "\nSpecify starting number <1>: ")) (1))))
        (if (setq s (ssget "_:L" '((0 . "TEXT") (1 . "~*[~0-9]*"))))
                (repeat (setq i (sslength s))
                    (setq x (entget (ssname s (setq i (1- i))))
                          a (cons (assoc -1 x) a)
                          b (cons (atoi (cdr (assoc 1 x))) b)
                (setq i (vl-sort-i b '<)
                      l (mapcar '(lambda ( n ) (nth n b)) i)
                (mapcar '(lambda ( x y z ) (entmod (list (nth z a) (cons 1 (itoa (if (= x y) n (setq n (1+ n)))))))) (cons nil l) l i)
  10. #10
    Junior Member
    Civil
    AutoCAD 2014
    Mar 2017
    12
    & & . Lee Mac, when I first read your message I laughed with my heart and then... wow... I have no words...! You are unbelievable! You know, I had written more than double of code lines than you, and I wasn't even in the middle! What can I say... Thanks man!! You know, what's impressive is not only that you solve the problem, but the way that you do it (and the speed of course ). Thanks again!
  1. Lisp for Auto numbering in ascending order while inserting block attributes
    By gmmdinesh in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Sep 2016, 11:21 am
  2. Finding Integers
    By b_clive in forum AutoCAD General
    Last Post: 9th Dec 2010, 10:46 am
  3. Numbering Ascending order
    By Kat in forum AutoCAD General
    Last Post: 18th Jan 2010, 02:13 pm
  4. sort ascending using VBA
    By priyanka_mehta in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Oct 2009, 12:59 pm
Tags for this Thread
