Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    Default during dragging no preview
    help me please, i have autocad mech 2013 in some dwgs conversions from other programs like me10 or solidworks, if i move, copy a blocks i don't see any preview the block with polylines disappear !!why? new block.dwg
    i insert an example, you must try to copy a block, in my cad i don't see anything when i move, for see something i must put the width to 0
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    For some reason Autocad is not liking the blocks and polylines in your drawing. Must be something to do with the conversion from whatever program created them. The only way I can get a preview of what's being copied or moved is to edit a block and explode all the nested blocks and explode all the polylines. Once I break down the elements of the block to just lines, arcs and circles, I can save the block and then copy or move normally, with a preview. That may not be an ideal solution, but it's the best I can come up with.
    One other thing. Why are your blocks so big? The diameter of the outer dashed circle is 321', and the block of the man is 146' tall.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by Cad64 View Post
    Interesting, when I open your drawing in Autocad 2013, the circle diameter is, as noted, 3500mms. The -dwgunits command reports the units as mms.
    The gentleman in question is about 1.75 meters tall, call it 70 inches, which doesn't seem entirely inappropriate.
    I haven't played around with the blocks yet, will report back shortly.
    I suspect your results are different than mine Cad64, because of a setting in OPTIONS.
    The blocks are all unitless.
    I suspect that as you are in the States, and your Target Units are likely Imperial, as compared to my settings in the screenshot.
    I was able to copy and drag bits around, and they displayed, and copied accurately.
    Typically we work with Unitless blocks, and our default database units are mms.
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    I am very happy that this bug happen to you . The file was converted from me10 i think or solidworks. I don t know why the block are so Big . I usually work with tunnel formworks . A man is height usually 1700mm. I work with mmm.
  5. #5
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    Quote Originally Posted by Dadgad View Post
    I suspect that as you are in the States, and your Target Units are Imperial, as compared to my settings in the screenshot.
    I am Italian and live in Italy.
    because you can? what is the cause thath don't display the objects during copy,moving etc... not only for me but even for Cad64
  6. #6
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    i check in user preferences and i use millimeters
    please see the first image the second i was wrong to upload sorry.
    in picture you see that near cursor i don't see the block
  7. #7
    AutoCAD 2013
    Nov 2011
    6,056
    Might you be talking about the Dynamic Input tools display?
    Or Grips, sorry, I am unclear as to what you hope to see displayed.
    Your screenshots are very small,
    When you say Tooltip Toolbox it makes me think of either GRIP Hover display (which you can turn on in OPTIONS on the SELECTION tab), or Dynamic Input (which can be turned on by entering F12), or clicking on the unchecked DY?? icon at the bottom of your screen, beside the OTRACK icon.
    I am not using Dynamic Input at the tooltip, just picking and clicking.
    In my earlier post I was suggesting that Cad64 was seeing something different than me, because his units are likely Imperial.
    I just saw your response, about being Italian, and working presumably in Metric.
  8. #8
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    I am able to draw both Lines & Polylines with no problems.
    Excuse me very much i put the wrong image, the right image is the first in which i drag a object and don't see nothing
  9. #9
    Senior Member
    Mechanical 2013
    Oct 2015
    154
    [QUOTE=Dadgad;681349] now i saw that i set the polyline width to 0.1 0.001 when move copy the polyline i don't see it so i suppose it is a bug!
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Have you seen the same thing happen in other drawings?
    Have your coworkers seen the same thing happening?
    Have you read anywhere else of cad techs, using Mech 2013, having experienced similar problems?
  1. Cannot select by window dragging
    By KarolR in forum Autodesk Inventor
    Last Post: 24th Jun 2012, 02:18 am
  2. Can I disable right click dragging?
    By thedarkmaster in forum AutoCAD Beginners' Area
    Last Post: 29th Jun 2011, 04:22 pm
  3. Dragging
    By qball in forum Tutorials & Tips'n'Tricks
    Last Post: 29th Jun 2009, 12:57 pm
  4. Dragging
    By Yankees24 in forum AutoCAD Beginners' Area
    Last Post: 24th Dec 2007, 04:57 pm
  5. dimensions not visible while dragging
    By cadsultant in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2005, 10:49 pm
