bababarghi Posted March 23, 2017 Share Posted March 23, 2017 Hi, I have heaps of drawing in front of me right now (500 almost). They all contain one Layout but with different layout naming pattern. The titleblock also doesn't necessarily sit in Layout space (they are in Model Space in some drawings) and they may also have different names e.g. "A3" or "HPT-A2" etc. My problem is, some of the title-blocks are exploded i.e. they do not contain attributes anymore (text objects only). How can I know what number of this drawing pile have exploded title-blocks and how many haven't? Quote Link to comment Share on other sites More sharing options...
rlx Posted March 23, 2017 Share Posted March 23, 2017 if (tblsearch "block" "title-block") returns nil (after a purge) or (ssget "x" (list (cons 0 "insert") (cons 2 "title-block"))) returns nil your title-block is kaput... if there are many names you can put them in a list or use a comma (cons 2 "title-block,A3,...") or a little more advanced use vl-some to try each name in a list.. many wayz gr.R. Quote Link to comment Share on other sites More sharing options...
bababarghi Posted March 23, 2017 Author Share Posted March 23, 2017 if (tblsearch "block" "title-block") returns nil (after a purge) or (ssget "x" (list (cons 0 "insert") (cons 2 "title-block"))) returns nil your title-block is kaput... if there are many names you can put them in a list or use a comma (cons 2 "title-block,A3,...") or a little more advanced use vl-some to try each name in a list.. many wayz gr.R. "title-block" string can be literally anything ! I just mentioned couple of samples in my first post. I don't have the list of available title block's names. Quote Link to comment Share on other sites More sharing options...
rlx Posted March 23, 2017 Share Posted March 23, 2017 No way a programm can guess a name so you have to feed it something... it can be a long list but the list is not endless. (defun tst ( / blk ) (if (setq blk (vl-some '(lambda (x)(if (tblsearch "block" x) x nil)) '("title-block" "A3" "term_1b"))) (alert (strcat "found block " blk))(alert "Not any valid block was found"))) That being said, I did (do) have the same problem were I work and I made a plan b were I scan every block and compare it against a template and look for centain key attributes but thats also is a lot of work and needs constant updating so there is no miracle cure for this problem , just hard work i'm afraid. Upside is , every time you update your list your routine gets more accurate. gr. R. Quote Link to comment Share on other sites More sharing options...
bababarghi Posted March 23, 2017 Author Share Posted March 23, 2017 How about purging all drawings first, and then extract the name of blocks which have say 10+ attributes in them (considering the fact that usually titleblocks hold 10+ attribute definition). What do you reckon? Quote Link to comment Share on other sites More sharing options...
rlx Posted March 23, 2017 Share Posted March 23, 2017 How about purging all drawings first, and then extract the name of blocks which have say 10+ attributes in them (considering the fact that usually titleblocks hold 10+ attribute definition). What do you reckon? Assuming certain attribute tagnames are always present , like 'revision' or 'drawing-number' you can loop trough all blocks and test if one or more attributes name are present. For me this alone does not always work because not all titleblocks have the same number of revision fields nor do they always have the same name. Only the drawing name field and main revision letter are almost always the same. So if you know just one attribute name that is always the same you would only have to look for that one. Quote Link to comment Share on other sites More sharing options...
rlx Posted March 23, 2017 Share Posted March 23, 2017 something 4U to play with : ; test (setq lst (RlxBlk_GetBlockList (vla-get-ActiveDocument (vlax-get-acad-object)))) (defun RlxBlk_GetBlockList ( $doc / fn O-Name B-Name A-Team B-Team) (if (vlax-property-available-p $doc 'Name) (setq fn (vla-get-name $doc))) ;(vlax-dump-object $doc) (vlax-for layout (vla-get-layouts $doc) (vlax-for object (vla-get-block layout) (setq O-Name (vla-get-objectname object)) (cond ((and (eq O-Name "AcDbBlockReference") (not (assoc (setq B-Name (vla-get-effectivename object)) B-Team))) (if (eq (vla-get-hasattributes object) :vlax-true) (setq B-Team (append B-Team (list (cons B-Name (mapcar '(lambda (x) (vla-get-tagstring x)) (vlax-invoke object 'getattributes)))))) (setq B-Team (append B-Team (list (cons B-Name (list "No Attributes"))))))) ((eq O-Name "AcDbAttributeDefinition") (setq A-Team (append A-Team (list (vla-get-tagstring object)))))))) (if B-Team B-Team (if A-team (list (cons fn A-team)) nil)) ) it's part of a much larger routine I'm currently working on but it might be of some use. This will list all blocks with all tagnames for any document so it also works with an odbx document gr.R Quote Link to comment Share on other sites More sharing options...
bababarghi Posted March 23, 2017 Author Share Posted March 23, 2017 something 4U to play with : ; test (setq lst (RlxBlk_GetBlockList (vla-get-ActiveDocument (vlax-get-acad-object)))) (defun RlxBlk_GetBlockList ( $doc / fn O-Name B-Name A-Team B-Team) (if (vlax-property-available-p $doc 'Name) (setq fn (vla-get-name $doc))) ;(vlax-dump-object $doc) (vlax-for layout (vla-get-layouts $doc) (vlax-for object (vla-get-block layout) (setq O-Name (vla-get-objectname object)) (cond ((and (eq O-Name "AcDbBlockReference") (not (assoc (setq B-Name (vla-get-effectivename object)) B-Team))) (if (eq (vla-get-hasattributes object) :vlax-true) (setq B-Team (append B-Team (list (cons B-Name (mapcar '(lambda (x) (vla-get-tagstring x)) (vlax-invoke object 'getattributes)))))) (setq B-Team (append B-Team (list (cons B-Name (list "No Attributes"))))))) ((eq O-Name "AcDbAttributeDefinition") (setq A-Team (append A-Team (list (vla-get-tagstring object)))))))) (if B-Team B-Team (if A-team (list (cons fn A-team)) nil)) ) it's part of a much larger routine I'm currently working on but it might be of some use. This will list all blocks with all tagnames for any document so it also works with an odbx document gr.R Tnx for sharing. I am thinking of modifying your code a little bit to write to *.TXT file and then apply that to the drawing package. Importing the final text file into something like Notepad++, I should be able to grab the list of drawings with titleblocks Quote Link to comment Share on other sites More sharing options...
rlx Posted March 24, 2017 Share Posted March 24, 2017 Tnx for sharing. I am thinking of modifying your code a little bit to write to *.TXT file and then apply that to the drawing package. Importing the final text file into something like Notepad++, I should be able to grab the list of drawings with titleblocks Youre welcome :-) you could, like you indicated earlier, first filter out all those blocks with less than 10 attributes , so you can keep your txt file as small as possible. Shouldn't be too difficult. gr. Rlx Quote Link to comment Share on other sites More sharing options...
