Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Forum Newbie
    AutoCAD 2017
    Mar 2017
    9
    Default Can't work with existing dwg
    Hi!
    Sorry if this is a really dumb or basic question. New (again) to AutoCAD -haven't used since 2006 so I am very rusty. Problem here is something I am sure is pretty simple to fix but I can't figure this out.
    I have two dwg's from both the architect and the designer. When I open either of the files I get a Proxy Information alert about an unavailable ObjectARX application. Then it alerts me that one or more reference files could not be located or read. If I try to open the External References palette, I get unreconciled new layers. When I am finally in the dwg, I can't access the lines to modify any of them. The only accessible layer seems to be the architect's and the designer's masthead layers. All other layers seem to be locked but I have tried doing everything from auditing and purging, I made sure Layer 0 was not frozen or locked, I have unlocked and thawed every layer but nothing allows me access to either drawings layers other than their mastheads.
    What simple thing am I missing to access the other layers in these files?
    Thanks for any input!!! My boss wants some changes made to these drawings for Monday to submit back to the architect and I'm not a designer anymore and my autocad knowledge is pretty bad now
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    What version of AutoCad do you use? Ask the other party to supply etransmit to the same version..
    You can use Trueview (free viewer) to convert dwg down. Install object enablers.
    Hope you can follow a bit ...
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    AutoCAD 2017
    Jul 2015
    671
    Or ..upload it to here if possible (for some time). Someone can help for sure..
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Do you know what programs the two drawings were created in?
    So you first tried opening each drawing then you next tried bringing them into your drawing as xrefs?
    Your boss didn't request that you change the architect's or designer's drawings did he?
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Are you trying to edit these files as an xref or are you opening the actual drawings? You mentioned the xref manager so I was not clear on your process.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    Forum Newbie
    AutoCAD 2017
    Mar 2017
    9
    Quote Originally Posted by halam View Post
    I'm using 2018 version. It does let me know that there is a version conflict when I try to save a copy. I will download trueview and try converting down first.
    Thank you!
  7. #7
    Forum Newbie
    AutoCAD 2017
    Mar 2017
    9
    Quote Originally Posted by rkent View Post
  8. #8
    Forum Newbie
    AutoCAD 2017
    Mar 2017
    9
    I know both were created in earlier versions of AutoCAD but not sure which one.
    I am just trying to open the drawings and I eventually can get into it but I receive these Proxy Information and Xref alerts when I do and then I can't access any lines to modify.
    Background: What I basically need to do is make a small modification to the kitchen plan of our new offices. We requested this change five times with the designer and she keeps changing the design to random layouts and it's never what we asked for. It takes her over a week to make a minor change and she sends it back with alterations all over the floor plan and it's costing us a fortune. It's a small change from the architect's original drawings and if I can just make these adjustments to the counters and millwork, we can resubmit to the architect and get the city approval for permits. It's such a minor change and I just need to go in and change the one layer in the two drawings but I can't get to them. I was an interior designer a million years ago and have *some* AutoCAD experience so now I'm in charge of sorting it out If I can't access the drawings to make the changes we're just going to have the architect do it, but my boss would rather just send him the completed drawings with our changes and not return another set with more notes yet again. It's holding up our entire move schedule.
  9. #9
    Forum Newbie
    AutoCAD 2017
    Mar 2017
    9
    How do I upload to here?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You came here looking for help and it would be nice if you answered some of the other questions as they may have a bearing on the situation.
  1. Add on to an existing command?
    By squareknees in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jul 2015, 07:35 am
  2. Replies: 2
    Last Post: 30th Sep 2011, 07:19 pm
  3. Replies: 33
    Last Post: 27th Jul 2011, 06:27 pm
  4. Rotating Already Defined Work Planes and Work Axis's
    By Randy Chard in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Mar 2009, 02:08 pm
  5. Using an existing drawing.
    By legend in forum AutoCAD Beginners' Area
    Last Post: 30th Dec 2007, 05:32 pm
Tags for this Thread
