gigi Posted March 24, 2017 Share Posted March 24, 2017 Hello, I am new to solid works and I am having trouble with a hole wizard part. Any help will be appreciated. I will attach a image of what I'm having trouble with, I cant get the dimensions I need. The hole should be made using hole wizard, linear pattern, & mirror, which i know how to do but cant get the dimensions right. Thanks Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 26, 2017 Share Posted March 26, 2017 what are the dimensions supposed to be? That says you have 8 holes that are 5mm diameter and down 11mm, then adds the tapped note. what is it supposed to be? Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 well I'm not to sure I'll attach the full schismatic and what i have completed so far. Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 Well I'm not to sure, I will attach the schematic. Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 well I'm not all to sure, this is another view. Thanks for the response Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 this is where im currently at Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 Well I'm not to sure sorry, Thanks for the response Quote Link to comment Share on other sites More sharing options...
gigi Posted March 26, 2017 Author Share Posted March 26, 2017 This is what i have done so far Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 29, 2017 Share Posted March 29, 2017 Gigi, i still don't follow whats wrong. That looks like a sample part for the CSWP exam right? I am curious as to why you say your dimensions are wrong. The last few images you tried to attach don't show. What you attached originally, was that your part or from the sample? The screen shot shows that you have added a tolerance to your hole that shouldn't be there. You have +- 0.25. You should be able to take what you have and do a linear pattern with a distance of 40mm along the construction line you have. Then make a midplane(depending on how you modeled it you might not need to create a plane) and mirror the "seed" and the 3 patterned holes. Quote Link to comment Share on other sites More sharing options...
