F2 key does not work for command history
hht
IIRC, the command line needs to be docked for F2 to make a new window. If it is not docked, the command line expands. Cannot test as I'm away from CAD ATM.
Try using Ctrl + F2, it is an alternate way to do it, which I did not know, but I also use 2013, and I went looking for it in the CUI.
Please explain how I can do? dock it?
Thank you.
With 2017 the text window will show whether the command line is docked or not. I would try the Ctrl+F2, and look in the CUI for the change.
Not with MEP 2017. Just tested and it behaves as I described above.
