Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2008
    May 2016
    1
    Question inserting DXF into drawing
    my problem is that elements in dxf file inserts on wrong coordinates.
    for example if the coordinate is 123456.78 inserted element is on 12345678.00
    I tried to change comma-dot in regional settings, but no change
    scale is ok, but elements are on wrong coordinates...
    The same thing is on fresh instal acad 2008 and 2013, but on my old computer with acad 2008 it's working. Dxf files are OK...
    any ideas?
    thanks
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    Check mm v's metres if your metric in the Units also when you use Insert Browse look at bottom right it has a scale factor make sure its 1.0
  1. inserting a BOM into a drawing
    By rhader in forum SolidWorks
    Last Post: 21st Oct 2011, 08:55 am
  2. inserting a file into a drawing
    By jquerel in forum AutoCAD Beginners' Area
    Last Post: 22nd Jul 2011, 12:36 pm
  3. Inserting notes in a drawing
    By Daniel Laroche in forum AutoCAD General
    Last Post: 16th Jul 2009, 04:11 pm
  4. Inserting a drawing problem!
    By lufc100 in forum AutoCAD Beginners' Area
    Last Post: 24th Feb 2009, 08:41 pm
  5. Inserting a drawing as a Block
    By bigr1822 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2008, 03:06 am
Tags for this Thread
