Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Why did you use DWGconvert? Can't you do a "saveas" in MEP 2013?
    Remark, converting the drawing is the proper way to do this. Using save as does not convert the newer objects and features to usable entities which could cause problems when opening the file in older versions. The conversion process takes care of those objects.
    Drafting is a breeze.
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,638
    As the OP stated, DWGconvert seemed to have misfired. I only suggested an alternative. I am not familiar with MEP 2013.
  3. #13
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You alternative probably won't give satisfactory results. This is a general rule of thumb when making files usable in older versions. It is not version or vertical specific. In fact, IMHO, the option to save as older versions shouldn't even be there as it only really works under certain circumstances.
  4. #14
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Considering this is posted in General Forum, one would be lead to believe the OP was using DWGConvert from DWG Trueview, which actually does work for me and AFAIK is the same DWGConvert in AutoCAD Mechanical.
    If the OP is using AutoCAD Mechanical, then this thread belongs in the Mechanical & MDT Forum, not sure where the MEP 2013 reference is coming from.
    Maybe you can post a file that isn't converting for you. I have saved down Mechanical drawings before, shouldn't make a difference except for proxy objects.
    Are you trying to open them in an older Mechanical or Vanilla AutoCAD?
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You're correct about it belonging in general and the OP needs to verify the settings used for the conversion wether he is using DTV or using AutoCAD's built in converter, which are actually the same thing.
  6. #16
    Senior Member
    Mechanical 2013
    Oct 2015
    109
    You are all so Kind thanks for help me ...I use dwg convert because i had 10 drawings to convert . I use mechanical and not vanilla. I conferm that dwg convert don t convert in 2000 version so i used save as one at a time for each dwgs
  7. #17
    Senior Member
    Mechanical 2013
    Oct 2015
    109
    Ok later when i will at home i post a screenshot of dwg convert .
  8. #18
    Senior Member
    Mechanical 2013
    Oct 2015
    109
    converted ac1027.dwgoriginal ac1027.dwgnow i attach the original file (i see the version with notepad and write the version in the name of the file) and then the dwg converted.
    for my disappoint the converted file is a ac1027 version the same of the original. i want convert in in 2000 with dwg convert but anything!
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Converted fine for me using DWG TrueView 2016. I can't really see your images that well.
  10. #20
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Maybe you should try using DWG TrueView, it is free from Autodesk.
  1. AutoCAD - Mass Convert DWG To DXF (Batch Convert DWG To DXF) (Mas DWG Convert)
    By kArThIcK hAcKeR in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 27th Oct 2017, 02:05 pm
  2. Convert line to 3dpoly, convert 3dfaces to polyface mesh
    By barbarossa in forum AutoCAD General
    Last Post: 3rd Nov 2016, 01:21 pm
  3. Convert HVAC radius elbow to segmented problem..
    By danglar in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Oct 2016, 12:57 pm
  4. Convert/PDF Problem
    By Randyman in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jun 2011, 08:13 pm
