Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    Default Strange Behavior or Bad Setting?
    Hi Folks,
    I'm using Autocad 2012 and just ran into a problem in my drawing.
    I will describe the symptoms:
    *My USC icon at the bottom left of the screen doesn't look right. Its just X and Y and 2 lines without any arrows.
    *Trying to draw a 2 x 2 square box.. The box will look square on the screen as I draw it but the dimensions being shown will not match.. One side will say 2 inches while the other side says some crazy number like 9 inches or something.
    Its almost as if my viewport and my USC are in two different worlds but I don't think I've done anything to cause it.
    What setting tells autocad to keep the USC with the viewport?
    More info: My lines in the Y direction don't match with the length displayed but if I draw it then go to measure, the measurement will be correct..
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    I just figured out that if I go to another location in my drawing, it works fine. But if I try to draw something within the structure I've already drawn, it doesn't work. Huh?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Would this be a 3D drawing by any chance?
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    Yes.. all 3d solids..
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    From your description of the UCS icon wouldn't that mean you are using a 2Dwireframe visual style? The icon is white in color? Have you tried this?
    "At the command line, type "UCS" then choose the "World" option. Next type "Plan" and choose "World".
  6. #6
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    I am using 2d wireframe.. My screen background is white so my UCS (x,y) indicator is black.
    Tried the USC>>World and then Plan>>World and no difference. My UCS icon doesn't look right.. its just two lines like an L.. no z indicated, no arrows, nothing.
    When I draw what looks like a square box on the screen, the X and Y are not even close. X is at 2 inches, Y is at 16 inches.
    Just noticed something.. This problem has something to do with an object I drew into the drawing. My project sits on a sloping hill and so I drew in the ground plane to help me visualize the slope that goes from east to west. From north to south its flat. If I'm looking at my slope from the east and I try to draw something within the area that represents the slope, that's when ACAD does the funny stuff. If I try to draw a cube outside of that inserted block, everything works fine. My UCS coordinate still looks funky though. I've never encountered this before.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You've skewed the UCS to match your ground plane that's why it looks odd from a top view.
    Can't you reorient your UCS so it lines up with the object on the hill?
    UCS = User Coordinate System
  8. #8
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    Its only giving me problems when I try to draw in an area of the ground plane... If I go outside that area, the UCS, or whatever is causing the problem, doesn't do it. So in other words, if I go to the far edges of my drawing limits and draw a box, it works fine.. if I try to draw it towards the center of the drawing limits, in an area where the ground plane is drawn, it acts up.. Boy am I confused on this one.
  9. #9
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    Yes.. the USC is matching the ground plane for some reason when I try drawing in that area! How do I turn that off?? When I try to draw a cube, the UCS tilts it to match the ground plane. I don't know why.
    The ground plane is a mesh.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    It sounds like you have Dynamic UCS enabled. Disable it (there is a toggle for it in the Task Bar) or freeze the layer it is on.
  1. Strange behavior of NCOPY function
    By danglar in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Mar 2017, 08:47 pm
  2. Strange behavior of files in Autocad LT
    By samifox in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jul 2016, 10:46 am
  3. VERY strange font behavior
    By Sbeth85 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Nov 2013, 09:25 am
  4. strange ZOOM OBJECT behavior
    By driutheman in forum AutoCAD General
    Last Post: 10th Apr 2006, 02:45 pm
  5. Strange behavior when using certain aliases
    By PLRuffo in forum AutoCAD General
    Last Post: 19th Jan 2006, 05:01 pm
