cat3appr Posted March 31, 2017 Share Posted March 31, 2017 hi all, I've searched in google but no precise answers to the following: I have a line at an angle that i don't know, i want to extend this line to a point of my preference ( no specific coordinates, but where i see it fit on the screen) but i want to extend it in a way that has the same direction of the line i'm extending from... I know that i could check the angle of that first line and draw the new line at the same angle, but iwant to do it in this other way... without checking the angle and drawing a new line, i want to extend a previous one at the same angle thanks! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 1, 2017 Share Posted April 1, 2017 The command you are looking for is EXTEND. Read and follow the commandline prompts. Alternately, you could use the SCALE command, and define your BASE POINT as the end which you want to stay where it is. once again, read the commandline prompts. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 1, 2017 Share Posted April 1, 2017 If you want a specific length just draw a circle then extend Quote Link to comment Share on other sites More sharing options...
welldriller Posted April 1, 2017 Share Posted April 1, 2017 (edited) If you want a specific length just draw a circle then extend BIGAL's circle is a good idea. I would go to where i want to extend the line to --> draw a line(in the opposite direction of the line i want to extend) -- then use the extend command. Just like BIGAL said. Edited April 1, 2017 by welldriller add informaton Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 1, 2017 Share Posted April 1, 2017 There are so many good, and different ways to skin a cat in Autocad. I use circles quite a bit like BIGAL suggested, for all kinds of different things. There are also a number of useful options available in DYNAMIC INPUT settings, as shown in the screenshot. Quote Link to comment Share on other sites More sharing options...
eldon Posted April 1, 2017 Share Posted April 1, 2017 Possibly use the command LENGTHEN with the DYnamic option. Quote Link to comment Share on other sites More sharing options...
hakmawongzi Posted April 1, 2017 Share Posted April 1, 2017 Or as simple as turning on "Object Snap" with the "Extension" option and extend away. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 1, 2017 Share Posted April 1, 2017 It could also be done with a simple grip edit using OSnap Tracking. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 1, 2017 Share Posted April 1, 2017 Possibly use the command LENGTHEN with the DYnamic option. Interesting, I have NEVER used this command, and with the commandline options of Total and Dynamic, pretty useful! Quote Link to comment Share on other sites More sharing options...
hakmawongzi Posted April 1, 2017 Share Posted April 1, 2017 Amazing, "Grip Edit" works with only two clicks of the mouse. The best method so far Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 3, 2017 Share Posted April 3, 2017 You could also scale the line using the opposite end as base point. Quote Link to comment Share on other sites More sharing options...
