zionshea Posted April 3, 2017 Share Posted April 3, 2017 Hello all, I have two display issues when I display the layout in one of the models: 1. When I add a Linear Dimension - the dimension line is display multiple times. ( please see ) 2. When I click on an object (e.g. a rectangle), the selection mark is displayed far a way and not on the object itself (please see ). Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 4, 2017 Share Posted April 4, 2017 I assume you had meant to attach a couple of screen shots but I'm not seeing them. When did these display issues first start showing up? What changes had you made to your system? Do the display issues affect every drawing or just one particular drawing? What steps have you taken so far to troubleshoot the display issues? Is hardware acceleration enabled? Does your system utilize an onboard graphics chip or a dedicated graphics card? What chip or card is being used? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 4, 2017 Share Posted April 4, 2017 Can't see any images. Maybe you can post images and a .dwg as well as give information on your computer specifications. To post files and Images read THIS. Quote Link to comment Share on other sites More sharing options...
zionshea Posted April 4, 2017 Author Share Posted April 4, 2017 Thanks ail for your replies. The problem was with my models in the layout - all models were assigned to Realistic view - I changed the view to Wireframe and all is OK now. I am attaching the two images for clarification. Thanks - this is closed now. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 4, 2017 Share Posted April 4, 2017 I've never had that problem using realistic visual style and dimensions. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 4, 2017 Share Posted April 4, 2017 Where are the dimensions located? In model space or in the layout? Quote Link to comment Share on other sites More sharing options...
