Results 1 to 9 of 9
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Default Install Vertical without plain Autocad
    On a system that does not have plain Autocad or any CAD platform at all, can you install directly a vertical Product?
    And if so, how can you load a plain Autocad Interface when a simple drawing setup is required in order to save time and have basic CAD ribbons and fucntionality
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Your profile says you are using AutoCAD 2007. Your thread suggests the possibility of an AutoCAD vertical program but you fail to mention which one.
    With a vertical product users can boot either to the vertical profile or the AutoCAD profile. You can access both profiles simply by having two desktop icons each with a specific path that defines what product should be opened. To open the AutoCAD product the path would look something like this:
    "C:\Program Files\Autodesk\AutoCAD <vertical product>\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD <vertical product>\AecBase.dbx" /p "AutoCAD"
    To open the AutoCAD vertical product the path would look something like this:
    "C:\Program Files\Autodesk\AutoCAD <vertical product>\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD <vertical product>\AecBase.dbx" /p "AutoCAD <vertical product>"
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Dont my mind my profile info. I'm talking about a scenario on a machine that has no CAD environment installed. Does it still required that Autocad is Installed first or can it do without
    Lets say its Map3D or Civil 3d that is required on a machine without Autocad. Do i need to first install Autocad then Civil or Map, or can i go ahead and install the verticals without having Vanilla AutoCAD?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I don't know as it's been a while since I installed a vertical product (AutoCAD Electrical). I would think not however.
    You could install your vertical product then set the profile from Options > Profiles and make your preferred profile current.
  5. #5
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    Quote Originally Posted by therock005 View Post
    I do not know about Map or Civil, other guys can and will chime in for that one. But for the AEC verticals (Architecture, MEP, etc) the answer is yes, you can install only the vertical without any prior installation of plain, vanilla AutoCAD. Granted, the plain, vanilla profile for AutoCAD is in fact installed, just not in the exact same directories and so forth. So vanilla AutoCAD will still technically be there and it's accessible via a Profile Switch upon the EXE shortcut that also gets installed for you if you select this option during the setup phase of the installation.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  6. #6
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Because the verticals run on top of the vanilla Autocad there is no need to install the vanilla Autocad. For instance with Civl3D, it runs on top of Map3D witch runs on top of Vanilla Autocad. So with one install of Civil3D you are installing 3 products so to speak.
    Murph
    Need a boat or camper for the weekend?
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    Like Murph_map you get two desktops Icons when you install Civ3D one as Civ3D and the other as Autocad.
  8. #8
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    thats what i wanted to know, thanx guys
  9. #9
    Senior Member
    jammie's Computer Details
    W7
    Civil
    jammie's Discipline Details
    Project Technician
    Civil
    AutoCAD 2016
    May 2006
    Ireland
    316
    As others have noted Civil3D will install AutoCAD if it's not on the machine
    In a network setup there is an advantage to installing AutoCAD first using one serial and carrying out another deployment for Civil 3D. If you have a license pool with limited Civil 3D licenses, some tasks may be suited to just AutoCAD. These tasks could be carried out from the vanilla AutoCAD licence pool which will free a Civil3D license for others.
    (Lmtools should cascade license. Running AutoCAD will use an AutoCAD license, Civil3D a Civil3D license)
  1. bug with autocad plain hatch when inserted in indesign
    By catlam in forum Design Software
    Last Post: 2nd May 2012, 09:44 pm
  2. Drawing pipes in PLAIN Autocad
    By bigN in forum AutoCAD General
    Last Post: 26th Oct 2011, 03:36 pm
  3. Map 3D as plain AutoCad?
    By Slaraffenmann in forum Map 3D
    Last Post: 19th Aug 2010, 12:38 pm
  4. Running MEP as plain ole' AutoCAD
    By Kremer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Jan 2010, 09:32 pm
  5. Plain AutoCAD for 3D Purpouses?
    By JLG-TX in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th May 2005, 02:47 pm
