MastroLube Posted April 6, 2017 Share Posted April 6, 2017 Hello guys, I've created this simple block that allow to draw armor in slab in a faster way. I'm not able to change the phi.. I've created the user parameter but the _regen doesn't work.. It still show as the default value.. any suggestion? blocco armatura.dwg Thanks, Dennis Quote Link to comment Share on other sites More sharing options...
MastroLube Posted May 18, 2017 Author Share Posted May 18, 2017 Hello guys, I get back to this project today.. Still be not able to upgrade this parameter inside a string. As you can see the length and the number of bars works well but not the diameter which is linked to a another field called PHI. Maybe I can draw a circle and put the diameter inside the string.. Do you have any suggestion, please? Thanks Dennis Quote Link to comment Share on other sites More sharing options...
MastroLube Posted May 18, 2017 Author Share Posted May 18, 2017 Something like that, maybe? blocco armatura.dwg Quote Link to comment Share on other sites More sharing options...
