Results 1 to 6 of 6
    Forum Newbie
    Architectural
    AutoCAD 2015
    Apr 2017
    2
    Default CAD Lisp code poly line vertex coords to txt file
    Hello,
    I'm using Lee Mac cad lisp program "PolyInfo V 1.3." for exporting polylines vertex coordinates. But for full work joy I need some modifications.
    URL for program: http://www.lee-mac.com/polyinfo.html
    URL for code: http://www.lee-mac.com/lisp/html/PolyInfoV1-3.html
    As you saw the program exports a lot of information about the polyline. So i want to modify the code that will export just polyline start vertex points x and y coords in two columns ( my cad version information exports to txt file ).
    The result should look like this:
    ________________________________
    Polyline starts points x
    649542.45
    649542.35
    649542.28
    Polyline starts points y
    495232.54
    495232.23
    495232.41
    Can someone help to figure out which part of code I must to modify to get the result i want? Please.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Have you tried his Point Manager ?
    Forum Newbie
    Architectural
    AutoCAD 2015
    Apr 2017
    2
    Unfortunately I did, but I'm using not exact AutoCAD program. I'm using ZW CAD. I's cheaper version of cad program. So the comand line promt " ** Dialog File could not be Written ** ". Yach sometimes not all lisp programs works.
    I just found an easier code of exporting X Y coordinates.
    URL : http://www.eng-tips.com/viewthread.cfm?qid=195727
    It is almost what i need. The result of code : (x coordinate) , (Y coordinate)
    But, can I change the code that coords print not in line, but in separated columns? for example:
    (x coordinate)
    (x coordinate)
    (Y coordinate)
    (Y coordinate)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    You can go back to 1st step basics and use the 'getcoordinates function then export what you want in the way you want. have a look at this example.
    Code:
    ; pline co-ords example
    ; By Alan H
    (defun getcoords (ent)
      (vlax-safearray->list
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy ()
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq len (length co-ords))
    (setq numb (/ len 2)) ; even and odd check required
    (setq I 0)
    (repeat numb
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    (setq I (+ I 2))
    ; program starts here
    (setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
    (co-ords2xy) ; list of 2d points making pline
    (princ co-ordsxy)
  5. #5
    Junior Member leo321's Avatar
    leo321's Computer Details
    w7 64bt
    TOSHIBA / DELL
    i5 3°generation
    4 gb other 6gb
    1gb other 2gb
    500gb
    2 tera
    21' and 17'
    Structural
    leo321's Discipline Details
    design Project
    Structural
    Pipelines, Industrials Units, Wind Farms, Minig, transmission line, thermoelectric, etc..
    AutoCAD 2012
    Jan 2013
    São Paulo / Brazil
    21
    want change this
    Labeling N,E Coordinates with Leader - David B. Stewart
    (defun C:LP(/ PNT1 P1X P1Y STDY DY COORDN COORDE PTXT)
    (setq PNT1 (getpoint
    "\nPick coordinate point: "))
    (setq P1X (car pnt1)) ;x coord
    (setq P1Y (cadr pnt1)) ;y coord
    (setq STDX (rtos P1X 2 2))
    (setq STDY (rtos P1Y 2 2))
    (setq COORDN (strcat "N=" STDY ))
    (setq COORDE (strcat "E= " STDX ))
    (setq PTXT (getpoint
    "\nPick text location: "))
    (command "LEADER" PNT1 PTXT "" COORDN COORDE "")
    come this way
    N=8566159.79
    E= 505422.47
    wanted this way
    N=8.566.159,79
    E= 505.422,47
    Want to know if it is possible that default
  6. #6
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    Quote Originally Posted by leo321 View Post
    wanted this way
    N=8.566.159,79
    E= 505.422,47
    never seen such number format, comma as decimal point?
    not this?
    N=8,566,159.79
    E= 505,422.47
    google "format number with thousand separator" many examples with others language as well
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  1. lisp needed : extract poly line vertex X,Y into txt file
    By ayman_48 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th May 2018, 05:54 am
  2. Lisp needed for Poly line with dimensions refference with building
    By YSRINY2I in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th May 2016, 11:48 am
  3. Lisp to import coords and code from txt/xls file...
    By goldy2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th May 2016, 10:44 am
  4. Replies: 1
    Last Post: 18th Jun 2015, 04:01 am
  5. Select polyline vertex coords by number
    By Johntosh in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2009, 01:33 pm
Tags for this Thread
