Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    28
    Default Filtering 3d solids
    Hi, I've got big assembly with 3d solid parts. Any ideas how can I find identical parts?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    Are all identical parts necessarily on the same layer? If they are then SELECTSIMILAR should work. If not then all the solids will be selected. Under the same scenario QSELECT should work as well.
    Unfortunately what I have seen from many users dabbling in 3D is they construct their model(s) on layer "0" then override the color of the object. If this is what you have done then I doubt SELECTSIMILAR would work, however, QSELECT should work using the criteria "3Dsolid" and the "color" assigned to the objects.
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    Probably looking for the same thing.
    I still need a better workflow to filter small parts, bolts etc, coming from dwg as converted import files.
    This guy is developing that looks like what you might want.
    He did mention it will be available soon on autodesk app shop.
    Since it is a dll i wait for the availability on app shop before testing it..
    https://plus.google.com/105412362761001542610
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    Until such time as it is available what are you recommending as a temporary solution?
  5. #5
    AutoCAD 2017
    Jul 2015
    671
    If you are lucky some dwg export from eg Tekla structures have a different 'material' for bolts. Look for something that can be filtered.
    It will probably not on layers.. (as i said, i'm looking for a tool to come to filter based on solid volume or mesh area or some other 3d property)
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  6. #6
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    28
    Thanks, but it would be too easy ....
    Unfortunately this is exported dwg assembly from, probably, Pro Structure and almost all parts are on one layer.
  7. #7
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    28
    Quote Originally Posted by halam View Post
    Thanks Halam,
    Did you try this solution?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    The parts are all on one layer. OK. Are these parts identified as blocks?
  9. #9
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,541
    I tried comparing the DXF values of (2) 3DSOLIDs
    1 That I made and a copy of that entity in the exact same location.
    Of the 400 +- geometry values, 2 had changed.
    So I doubt you will be able to identify identical pieces.
    Due the fact that the solids geometry values are stored in a binary format, decrypting the info is all but impossible without AutoDesk reveling their secrets. -David
    R12 (Dos) - A2K
  10. #10
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    28
    No blocks, just 3d solids. Of course they are grouped on separately layers. Like Beams, Plates, Bolts and so on.
    But I need find the identical parts inside these groups.
    Differences in geometry are usually not too big.
  1. Filtering out objects in ssget
    By jesset in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2017, 05:50 am
  2. Filtering Vertices
    By grouch19 in forum AutoCAD General
    Last Post: 2nd Dec 2013, 09:57 pm
  3. Filtering objects in ActiveSelection
    By Grenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2009, 10:41 am
  4. Block Search by Filtering
    By The Buzzard in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2009, 08:30 pm
  5. Layer filtering
    By Meatarian in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Feb 2005, 02:22 am
