Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
  1. #11
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Quote Originally Posted by David Bethel View Post
    I tried comparing the DXF values of (2) 3DSOLIDs
    1 That I made and a copy of that entity in the exact same location.
    Of the 400 +- geometry values, 2 had changed.
    So I doubt you will be able to identify identical pieces.
    Due the fact that the solids geometry values are stored in a binary format, decrypting the info is all but impossible without AutoDesk reveling their secrets. -David
    But AutoCad can read volume of 3d solid ...
    It seems it could be possible.
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Quote Originally Posted by JamesBorubar View Post
    No blocks, just 3d solids. Of course they are grouped on separately layers. Like Beams, Plates, Bolts and so on.
    But I need find the identical parts inside these groups.
    Differences in geometry are usually not too big.
    So the only way to differentiate between two bolts the exact same diameter but different lengths would be by their volume. Is that what you are attempting to do?
  3. #13
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Yes, but I don't know how to set filter. What filter in AutoCad can do it?
  4. #14
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    This one sure has a lot to filter, but not 3d props (?) There should be a alternative way in retrieving a selectionset based on a 3d bounding box. Not easy..
    https://apps.autodesk.com/ARCH/en/De...en&os=Win32_64
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  5. #15
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Quote Originally Posted by halam View Post
    Probably looking for the same thing.
    I still need a better workflow to filter small parts, bolts etc, coming from dwg as converted import files.
    This guy is developing that looks like what you might want.
    He did mention it will be available soon on autodesk app shop.
    Since it is a dll i wait for the availability on app shop before testing it..
    https://plus.google.com/105412362761001542610
    I've tried AVC_SelectSame.bundle. It works pretty good!
    Many Thanks Guys for your help
    James
  6. #16
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    Using massprop the only common object would be the volume the "principal moments" are the same only if the objects are in same plane ie turn 90 the 3 values will be the same but in different order I J K, J I K so if you were to sum them then parts may the same, would need testing.
  7. #17
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    James
    Hi, I've found problem with mirrored parts: the same volume and the same Area ...
  8. #18
    AutoCAD 2017
    Jul 2015
    699
    This app is available now. Not tested it myself yet.
    https://apps.autodesk.com/ACD/en/Det...en&os=Win32_64
  9. #19
    AutoCAD 2017
    Jul 2015
    699
    This tool works good for most of my needs!
    Its definitly worth the 5 bucks
    https://youtu.be/I9O0_fSmoCc
  10. #20
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Halam, I agree with you. Thanks
  1. Filtering out objects in ssget
    By jesset in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2017, 05:50 am
  2. Filtering Vertices
    By grouch19 in forum AutoCAD General
    Last Post: 2nd Dec 2013, 09:57 pm
  3. Filtering objects in ActiveSelection
    By Grenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2009, 10:41 am
  4. Block Search by Filtering
    By The Buzzard in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2009, 08:30 pm
  5. Layer filtering
    By Meatarian in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Feb 2005, 02:22 am
