Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    After paying the 5 bucks ;-) .. i am using this app for some time now
    He seems to have fixed the returning activation /wating menu.
    This works really good for 3d purposes imo.
    Check this out.
    https://youtu.be/yTB4L_gqees
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  2. #22
    Forum Newbie AVC's Avatar
    AVC's Computer Details
    Windows 7, Windows Server 2012
    Manufacture
    AVC's Discipline Details
    Head of Engineering & IT Departments
    Manufacture
    Furniture and Exhibition stands
    AutoCAD 2018
    May 2017
    Moscow
    3
    Hi guys. I just registered here. I am the author of the program mentioned above. I recommend downloading plugins from my site and not using the Autodesk store. The Autodesk store always has old versions of programs because there is a very long moderation.
    On this topic, I want to say that I have been trying to create an optimal algorithm for searching identical solids for more than ten years. This problem is not trivial. You can not choose the same solids based on their volume. Too much chance of coincidence. In addition, the Autocad has large errors in calculations and can calculate a different volume for one solid if it is slightly rotated. This is especially noticeable on solids based on splines. Therefore, in my plug-ins I first lay out the details in the XY plane, then measure the volume, then I check the displacement of the center of gravity (asymmetry). But even such an algorithm does not give a 100% guarantee.
  3. #23
    AutoCAD 2017
    Jul 2015
    671
    Good to know the details how it behaves on 3d volume Alexandr
    Nothing is perfect, even though it runs on AutoCAD;-)
    Personally, I never trust computer 100% and check the outcome.
    What can you say if, for instance, area or perimeter is used,
    Is this something that is used in a 'none alogaritmic matter'?
    Regards hans
  4. #24
    Manufacture
    Manufacture
    AutoCAD 2018
    May 2017
    Moscow
    3
    Quote Originally Posted by halam View Post
    Perimeter and area will be subject to the same problems as volume. And I think there will not be much difference in computing speed. However, the combination of area and volume will yield fewer false coincidences.
    For example, I just encountered problematic details. The details are identical, but the holes are slightly moved in them. In no way is it possible to specify that these are different details. The volume, perimeter, area - all are identical. My algorithm calculates a slightly different parameter "asymmetry", but it does not save because it too similar to the error of calculations. Of course this is a very rare case, but it sometimes happens.
    There are 2 ways to solve this problem -
    1. Complete analysis of bRep
    2. Partial analysis of bRep (only to find the reference face), rotate in the same way, and subtraction of one solid from the other.
    But everyone understands how long this will work if it is necessary to subtract the solids many thousands of times....
    So far I just ignore such cases. I tell guys from my team the Russian saying: "Doveray, no proveray!" (Trust him but check him!)
  5. #25
    AutoCAD 2017
    Jul 2015
    671
    Haha.. "Doherty no perverty" I'll be saying that
  6. #26
    Manufacture
    Manufacture
    AutoCAD 2018
    May 2017
    Moscow
    3
    SelectSame-plugin is now available for the BricsCAD too https://sites.google.com/site/avcplugins/selectsame
  1. Filtering out objects in ssget
    By jesset in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2017, 05:50 am
  2. Filtering Vertices
    By grouch19 in forum AutoCAD General
    Last Post: 2nd Dec 2013, 09:57 pm
  3. Filtering objects in ActiveSelection
    By Grenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2009, 10:41 am
  4. Block Search by Filtering
    By The Buzzard in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2009, 08:30 pm
  5. Layer filtering
    By Meatarian in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Feb 2005, 02:22 am
