Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    218
    Default Which command to FLATSHOT in ver 2006
    Is there a command to project the 3D model onto the XY plane, like the FLATSHOT command in ver 2013?
    AutoCAD 2013
    Nov 2011
    6,056
    Do you have the command SOLPROF available in 2006?
    I believe you do.
    That would be my suggestion.
    SOLVIEW and SOLDRAW can be used together to do it, but I prefer SOLPROF.
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    218
    SOLPROF works in Paper Space. I want to project the 3D solids on the XY plane of the current UCS in Model Space
    AutoCAD 2013
    Nov 2011
    6,056
    The SOLPROF command is activated through an active Paperspace viewport, or a Maximized viewport, but the line work generated is in Modelspace, on the X,Y plane of the current UCS.
  5. #5
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,673
    Doesn't 'flatshot' work in 2013? I have it in 2017.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    In the title of the first post the OP mentions needing an equivalent function for Autocad 2006.
  7. #7
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,673
    Oops, got it backwards I guess I thought I remember using it in '05, might not have been. That was a while ago.
  8. #8
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by f700es View Post
    I haven't a clue, had no idea it was anywhere near that old.
    I started on 2009.
  9. #9
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    218
    I started working with Autocad from version 12, i think. and then 13, 14 and 2000. i am somewhat old.
    Thank you Dadgad
  10. #10
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by KarolR View Post
    Thank you Dadgad
    Were you able to get what you needed with SOLPROF?
    Sounds like you probably did.
    I just checked, and the VPMAX command was added to autocad in 2005.
    Create and activate a viewport (even if it will be a throw away, later), then VPMAX will take you through to Modelspace, and at that point you will be able to run SOLPROF, while seemingly in Modelspace.
    I used to use it all the time for fabrication drawings, before we switched to ProSteel, which spits out the drawings automagically.
    Somewhat old is an interesting concept, as in who isn't? Compared to SOMETHING.
    I started on 2009, at the age of 58, choose to think of myself as somewhat young.
    For some inexplicable reason.
    Like so many perceptions, it is all a matter of one's perspective.
  1. Erratic lines in FLATSHOT command acad 2013
    By PGuatney in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Oct 2012, 03:06 pm
  2. TEXT command made in MSexcel fail to execute in command line Autocad 2006 and higher
    By ctdlc888 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Sep 2011, 04:05 am
  3. 2010 MEP Piping & The Flatshot Command
    By Kremer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Dec 2009, 04:58 pm
  4. Flatshot command does not show tangential edges
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 19th Oct 2006, 12:00 am
  5. trim command in 2006
    By Bryan D Adams in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2006, 06:39 pm
