Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    218
    Thank you Dadgad and f700es
  2. #12
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,673
    You're welcome. Not sure if this will work for you but you could always setup a dxb printer in AutoCAD to "print" out a 2D representation of your 3D file.
    https://knowledge.autodesk.com/suppo...D2D57-htm.html
    After this you can use the dxbin command to insert this 2D file. I used this method before with good results at times.
    Good luck
    Sean
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  3. #13
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    Quote Originally Posted by f700es View Post
    Good luck
    Sean
    Good point Sean,
    I use DXB plotting extensively. Be aware that it is based on very old ( integer based ) technology and that 1:1 plotting is not extremely accurate.
    -David
    R12 (Dos) - A2K
  4. #14
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,673
    Yeah it has "issues" for sure but can work in certain situations.
  5. #15
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    What about FLATTEN? Wasn't that an Express Tools item for AutoCAD 2006? Not as accurate or as clean as FLATSHOT but it worked.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  6. #16
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,673
    It should be but I don't think that the OP wants to destroy his design to get his 2d image. So sure, just make a copy and use flatten. Flatten only works on solids iirc and I think flatshot as well. The DXB method works on any acad item. Good idea on flatten. :thumbsup
  7. #17
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    Yeah, Solid Profile is the way to go for no conversion. Sounds like best option overall, or only option really.
    For the record, I think FLATSHOT eventually was made to work with mesh in addition to solid objects, can't remember which version it was adopted though.
    -TZ
  8. #18
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,673
    Ah, it might have been. I haven't tried FL in a while myself.
  1. Erratic lines in FLATSHOT command acad 2013
    By PGuatney in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Oct 2012, 03:06 pm
  2. TEXT command made in MSexcel fail to execute in command line Autocad 2006 and higher
    By ctdlc888 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Sep 2011, 04:05 am
  3. 2010 MEP Piping & The Flatshot Command
    By Kremer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Dec 2009, 04:58 pm
  4. Flatshot command does not show tangential edges
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 19th Oct 2006, 12:00 am
  5. trim command in 2006
    By Bryan D Adams in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2006, 06:39 pm
